Deployment failure - Raptor, using VS 2013
Reviewed past problems people had with this and have made sure I did all that…started a brand new project, using 4.3. Using a Raptor board (also tried Reaper).
Receiving this error when trying to deploy: (scroll down as needed, the issue is at the bottom)
Create TS.
Loading start at 202de498, end 2030d92c
Assembly: mscorlib (4.3.1.0) Assembly: Microsoft.SPOT.Native (4.3.1.0) Assembly: Microsoft.SPOT.Security.PKCS11 (4.3
.1.0) Assembly: System.Security (4.3.1.0) Assembly: Microsoft.SPOT.Hardware (4.3.1.0)
Assembly: Microsoft.SPOT.Graphics (4.3.1.0) Assembly: Microsoft.SPOT.TinyCore (4.3.1.0)
Assembly: Microsoft.SPOT.IO (4.3.1.0) Assembly: System.IO (4.3.1.0) Assembly: Microsoft.SPOT.Hardware.Usb (4.3.1.0)
Assembly: Microsoft.SPOT.Hardware.SerialPort (4.3.1.0) Assembly: Microsoft.SPOT.Touch (4.3.1.0)
Assembly: Microsoft.SPOT.Ink (4.3.1.0) Assembly: Microsoft.SPOT.Hardware.PWM (4.3.1.0)
Attaching deployed file.
Assembly: GTM.GHIElectronics.LED7C (4.3.8.1) Attaching deployed file.
Assembly: Gadgeteer (2.43.1.0) Attaching deployed file.
Assembly: GHI.Hardware (4.3.8.1) Attaching deployed file.
Assembly: GTM.GHIElectronics.CharacterDisplay (4.3.8.1) Attaching deployed file.
Assembly: GTM.GHIElectronics.Joystick (4.3.8.1) Attaching deployed file.
Assembly: Gadgeteer.Serial (2.43.1.0) Attaching deployed file.
Assembly: GTM.GHIElectronics.Button (4.3.8.1) Attaching deployed file.
Assembly: GHIElectronics.Gadgeteer.FEZRaptor (4.3.8.1) Attaching deployed file.
Assembly: GTM.IngenuityMicro.RfPipe (1.0.1.0) Attaching deployed file.
Assembly: GTM.GHIElectronics.USBClientDP (4.3.8.1) Attaching deployed file.
Assembly: Microsoft.SPOT.Net (4.3.1.0) Attaching deployed file.
Assembly: GTM.GHIElectronics.Tunes (4.3.8.1) Attaching deployed file.
Assembly: FrontDoorRAPTOR (1.0.0.0) Attaching deployed file.
Assembly: GTM.GHIElectronics.BreadBoardX1 (4.3.8.1) Attaching deployed file.
Assembly: GTM.GHIElectronics.RFIDReader (4.3.8.1) Attaching deployed file.
Assembly: GHI.Usb (4.3.8.1) Resolving.
Assembly: GTM.IngenuityMicro.RfPipe (1.0.1.0) needs assembly ‘Microsoft.SPOT.Hardware.SerialPort’ (4.3.0.0)
Assembly: GTM.IngenuityMicro.RfPipe (1.0.1.0) needs assembly ‘Gadgeteer’ (2.43.0.0)
Assembly: GTM.IngenuityMicro.RfPipe (1.0.1.0) needs assembly ‘mscorlib’ (4.3.0.0)
Assembly: GTM.IngenuityMicro.RfPipe (1.0.1.0) needs assembly ‘Microsoft.SPOT.Hardware’ (4.3.0.0)
Assembly: FrontDoorRAPTOR (1.0.0.0) needs assembly ‘GTM.IngenuityMicro.RfPipe’ (1.0.1.0)
Error: a3000000
Waiting for debug commands…
The program ‘[1] Micro Framework application: Managed’ has exited with code 0 (0x0).
Attaching two screenshots showing I have the Project pointed to 4.3 and the firmware is up to date.
Any ideas?
…and Happy Eve!
It looks like you are using the driver for RFPipe that was compiled against NetMF 4.3.0.0 You will need to obtain a version that was compiled against NetMF 4.3.0.1.
I am pretty sure that Justin has updated libraries to cover this.
Makes perfect sense, thanks! Makes perfect sense, thanks! I’ll be in touch him.
Justin is out for the holidays so I don’t want to bug him more than I already have (he’s helping me with something else and is crazy busy); I searched throughout the web for RFpipe drivers which will work for 4.3 SDK and couldn’t find any. Does anyone have some on hand I can download? Trying to get this project off the ground and this is the final obstacle.
(tried GIthub and ingenuitymicro website but no luck)
I’ll PM you a link to my onedrive where I think I have the Ingenuity Micro 4.3.1 SDK
Edit: PM sent
@ Brett -
Excellent, thank you very much!
Looks like my evening spare hour just filled up.
