Hi All,
I’m using the FEZ Cobra, Glide and VS2010 Express to create an application. The application has a lot of code and everything works fine until I add a reference to the GHIElectronics.NETMF.IO assembly. The code builds but when I try to deploy it to my Cobra using the “Start Debugging” option, my Cobra freezes and VS never finishes deploying. When I remove the reference to the GHIElectronics.NETMF.IO assembly everything works as usual again.
I’m trying to write code to use an SD card to save settings etc. for my application. I copied the persistent storage SD/USB code example from the NETMF libraries. I made a test project with just the persistent storage code to test it before I copy/pasted the code to my real project. So I know the persistent storage code and my original code work separately. But I can’t get them to work together.
Any suggestions?
