Hi
I’m deploying a project to my Fez Hydra, but I get Device not found or cannot be opened - USB:Gadgeteer =(
I have tested depploying a File->new project and then only adding the Hydra board and the UsbClientDP but the problem persist.
I have tested with different usb cabels and connect via powered usb hub and directly to the computer but no change.
If I check the “.NET Micro Framework” tab under project properties it says Tranport: USB and Device “FEZ Hydra_FEZHydra”.
Using the same setup (changing only the motherbord to a FEZ Spider) it works without any problem.
This is the first time I use my hydra could it be broken or am I miss something else?
Cheers
/Jimmy
Did you update the firmware?
That was my first thoght, but the firmware updater doesn’t fint the Hydra either, forgot to mention that.
Then you can try to do it manually http://wiki.tinyclr.com/index.php?title=Firmware_Update_FEZ_Hydra
But maybe your PC is not seeing it at all. What do you see under device manager? Can you ping it from MFDeploy?
Thanks I’ll try that
My device manager says a .Net Micro Framework Device is connected
No response when pinging from MFDeploy
What do you see in “Devices & Printers”?
Under Device & Printers I see “FEZ Hydra”
If you are correctly booted into the TinyBooter then you should see an icon like this one. Try the method of placing a wire between pins 8 & 10 of socket 3 to get into this mode before trying to update the firmware.
Now I have tested to update the firmware using an SD card.
After reboot I get a GPS Camera Detect (COM3) and when running UpdateFEZHydra.bat it takes a REALLY (30+ min) long time and the log doesn’t open.
Looking in the log (in the same folder) the last rows are:
-I- Erasing: 0x18C0 bytes at address 0x41D6C0
-I- Erasing: 0x18C0 bytes at address 0x41EF80
-I- Send File FEZ_HYDRA_TINYBOOTER.bin at address 0x8400
GENERIC::SendFile FEZ_HYDRA_TINYBOOTER.bin at address 0x8400
-I- File size : 0xEA4C byte(s)
-I- Writing: 0x18C0 bytes at 0x8400 (buffer addr : 0x302CD8)
-I- 0x18C0 bytes written by applet
-I- Writing: 0x18C0 bytes at 0x9CC0 (buffer addr : 0x302CD8)
-I- Writing: 0x18C0 bytes at 0xB580 (buffer addr : 0x302CD8)
-I- Writing: 0x18C0 bytes at 0xCE40 (buffer addr : 0x302CD8)
-I- Writing: 0x18C0 bytes at 0xE700 (buffer addr : 0x302CD8)
-I- Writing: 0x18C0 bytes at 0xFFC0 (buffer addr : 0x302CD8)
-I- Writing: 0x18C0 bytes at 0x11880 (buffer addr : 0x302CD8)
-I- Writing: 0x18C0 bytes at 0x13140 (buffer addr : 0x302CD8)
-I- Writing: 0x18C0 bytes at 0x14A00 (buffer addr : 0x302CD8)
-I- Writing: 0xB8C bytes at 0x162C0 (buffer addr : 0x302CD8)
-I- 0xB8C bytes written by applet
-I- Temp file : C:/Users/Jimmy/.sam-ba.testCompareFile
-I- Compare File : FEZ_HYDRA_TINYBOOTER.bin with memory at address : 0x8400 , for 59980 byte(s)
-I- Read File C:/Users/Jimmy/.sam-ba.testCompareFile at address 0x8400
GENERIC::ReceiveFile C:/Users/Jimmy/.sam-ba.testCompareFile : 0xEA4C bytes from address 0x8400
-I- Reading: 0x18C0 bytes at 0x8400 (buffer addr : 0x302CD8)
-I- Reading: 0x18C0 bytes at 0x9CC0 (buffer addr : 0x302CD8)
-I- Reading: 0x18C0 bytes at 0xB580 (buffer addr : 0x302CD8)
-I- Reading: 0x18C0 bytes at 0xCE40 (buffer addr : 0x302CD8)
-I- Reading: 0x18C0 bytes at 0xE700 (buffer addr : 0x302CD8)
-I- Reading: 0x18C0 bytes at 0xFFC0 (buffer addr : 0x302CD8)
-I- Reading: 0x18C0 bytes at 0x11880 (buffer addr : 0x302CD8)
-I- Reading: 0x18C0 bytes at 0x13140 (buffer addr : 0x302CD8)
-I- Reading: 0x18C0 bytes at 0x14A00 (buffer addr : 0x302CD8)
Nothing else
Any suggestions?
/Jimmy
FEZs can be finicky about which SD cards they like. If you have a different SD card, give that a try. It looks like it’s losing communications or data in the middle of the process. Also, you might try downloading the firmware files again just to be sure they aren’t corrupt.
Sorry for not replying sooner.
Got it working finaly =) \o/
What I did was updating the firmware manually following the guide above.
Connected to a power usb hub I got the “interuption” problem sbove , but when connnected directly to the computer everything worked.
Thanks for all the help
Cheers
/Jimmy
Glad it is working for you.
I was just now struggling with a similar problem with FEZ Spider. I’m posting my solution just for the case anybody else is having the same problem.
SYMPTOMS:
Visual Studio was reporting linking errors with some assemblies, so I updated the firmware. After that, I was unable to deploy anything to the device. I was only getting the error “Device not found or cannot be opened - USB:Gadgeteer”.
SOLUTION:
The config tool was connecting to the device without any problems, and was reporting the device name ESX_ESX. I noticed however, that under Devices & Printers in the Control Panel, the name is just ESX. I updated the name in VS Project Properties, Micro Framework tab, and now everything works as a charm.
