Hello, i finished to develop the net gadgeteer project in VS 2012, successfully deployed the assemblies to FEZ Raptor. Now i want to deploy my project to another FEZ Raptors, but i am going to keep my source code private. Is there any solution or tutorial how to do it? Thank you.
In mfdeploy, look for create application deployment…
Ok, i found this option. It creates the .hex file. That is all i need? After make a deployment project (.hex) just connect another FEZ Raptor and deploy this file to it? Sorry for a stupid questions i just want to make sure that i am on the right direction, dont want to make a brick from my friends fez… thank you.
Yes that is all you need.
As long as the Raptor’s have the same firmware then that is all you need to deploy your code. If you build with a different one you will need to supply the firmware as part of the update.
Thank you very much for replies
