Found debugger!
Found debugger!
Create TS.
Loading start at a0e00000, end a0e1383c
Assembly: mscorlib (4.2.0.0) Assembly: Microsoft.SPOT.Native (4.2.0.0) Assembly: Microsoft.SPOT.Security.PKCS11 (4.2
.0.0) Assembly: System.Security (4.2.0.0) Loading Deployment Assemblies.
Attaching deployed file.
Assembly: Microsoft.SPOT.Hardware.PWM (4.2.0.1) Attaching deployed file.
Assembly: Gadgeteer (2.42.0.0) Attaching deployed file.
Assembly: GHIElectronics.NETMF.Glide (0.1.0.6) Attaching deployed file.
Assembly: Microsoft.SPOT.Hardware (4.2.0.0) Attaching deployed file.
Assembly: GHI.Premium.Hardware (4.2.11.0) Attaching deployed file.
Assembly: Microsoft.SPOT.IO (4.2.0.0) Attaching deployed file.
Assembly: GTM.GHIElectronics.Display_T35 (4.2.100.0) Attaching deployed file.
Assembly: Microsoft.SPOT.Touch (4.2.0.0) Attaching deployed file.
Assembly: System.Xml (4.2.0.0) Attaching deployed file.
Assembly: GTM.GHIElectronics.UsbClientDP (4.2.100.0) Attaching deployed file.
Assembly: Microsoft.SPOT.Graphics (4.2.0.0) Attaching deployed file.
Assembly: Microsoft.SPOT.TinyCore (4.2.0.0) Attaching deployed file.
Assembly: System.IO (4.2.0.0) Attaching deployed file.
Assembly: GHI.Premium.System (4.2.11.0) Attaching deployed file.
Assembly: GHI.Premium.IO (4.2.11.0) Attaching deployed file.
Assembly: Microsoft.SPOT.Net (4.2.0.0) Attaching deployed file.
Assembly: GLIDE_TEST (1.0.0.0) Attaching deployed file.
Assembly: GHIElectronics.Gadgeteer.FEZSpider (4.2.100.0) Resolving.
Assembly: GHIElectronics.NETMF.Glide (0.1.0.6) needs assembly ‘mscorlib’ (4.1.2821.0)
Assembly: GHIElectronics.NETMF.Glide (0.1.0.6) needs assembly ‘Microsoft.SPOT.Native’ (4.1.2821.0)
Assembly: GHIElectronics.NETMF.Glide (0.1.0.6) needs assembly ‘Microsoft.SPOT.Graphics’ (4.1.2821.0)
Assembly: GHIElectronics.NETMF.Glide (0.1.0.6) needs assembly ‘System.Xml’ (4.1.2821.0)
Assembly: GHIElectronics.NETMF.Glide (0.1.0.6) needs assembly ‘Microsoft.SPOT.Touch’ (4.1.2821.0)
Assembly: GHIElectronics.NETMF.Glide (0.1.0.6) needs assembly ‘System.IO’ (4.1.2821.0)
Assembly: GHIElectronics.NETMF.Glide (0.1.0.6) needs assembly ‘Microsoft.SPOT.Hardware’ (4.1.2821.0)
Assembly: GLIDE_TEST (1.0.0.0) needs assembly ‘GHIElectronics.NETMF.Glide’ (0.1.0.6)
Error: a3000000
Waiting for debug commands…
Il programma ‘[19] Micro Framework application: Gestito’ è terminato con il codice 0 (0x0).
