I have FEZ with 7" display. Running the latest versions of TinyBooter and EMX firmware. Have my application running just fine. Created a deployable application with MFdeploy. But …
When I select this application and deploy it to my other FEZez most of the time I get the error “Signature check failed for file …”. Tried erase, rebooting CLR, reboot and stop, but there is not an obvious reason for this error it seems. Sometimes the 1st time I have a deploy error and when I deploy the same app again the app loads fine.
Also, when I perform a Reboot CLR after have received the signature error, the applicatioin is there and runs fine.
What is causing this kind of trouble and how can I solve it? Any suggestions?
