Now I am trying to extract the image to deploy it to other USBizi board.
But the deploy tools tells
"Device has old or unsupported configuration"
when I do Target->Create Application Deployment
How do I fix this.
I am using MF Deploy 4.1.2821.0
This is different form EMX.
Please check USBizi user manual for details.
Put the board in BL mode first using the BL#/Loader pin.
You should see a COM port. Make sure you can send a get version command.
Next initiate XModem receive, it should work fine.
You must have one old USBizi. 1.05 is very old an these commands are not supported.
From user manual:
“Updating your managed application from the GHI boot loader is available from boot
loader version 1.06 and above.”
