Decode
Hello,
i linked an arduino and a fezpanda2 by UART. But when i send for exemple 20, fez receive 48. So i saw that the message is cut in chars or something else.
Can you help me to convert to recover 20.
thx.
Show us your code, please.
byte[] recu_data = new byte[1];
bool recue = false;
 while (recue == false)
                    read_count = Sender.Read(recu_data, 0, 1);
                    if (read_count > 0)
                        recue = true;
 Debug.Print(recu_data[0].ToString());
try…
Debug.Print(new string(Encoding.UTF8.GetChars(recu_data[0], 0, 1);
You are probably sending 20 as a string. 48 is decimal value of the ascii character ‘0’. So you probably receiving 50 and 48.
i can’ write
there are an error. But when i write :
Debug.print(Encoding.UTF8.GetChars(recu_data).ToString();)
it print : System.Char[]
yes,i saw that i receive 2 different values : 48 and 50. How can i convert them and assemble them ?
Because i receive the second value, just if i do a second read of the message.
My bad. That was quick & dirty… Try it like this.
Debug.Print(new string(Encoding.UTF8.GetChars(recu_data, 0, 1);
no, i have an error
Debug.Print(new string(Encoding.UTF8.GetChars(recu_data, 0, read_count);
Finally i succeeded,
fez code :
String part1 = recu_data[0].ToString();
Debug.print(par1);
but i used an other method to send message in arduino.
 Serial.write(20);
Before i used
Serial.print(20);
and it send String. But the “Serial.write” send a single byte.
Thanks for help :wink:
Excellent. I figured all you needed was to know about the Encoding library and you’d figure it out :wink:
