When inspecting my JSON string in the debugger it does now show full value but writing it to Debug window the full value is there.
using VS2022
using VS2022
I looked through some older source code (from netmf) and it looks like a lot of the buffers that the debug protocol uses are limited to 128 characters, which is pretty close to what you show there when I count up text and presumed whitespace characters. That’s not a smoking gun, but I’d bet better than even money that that’s the limit for a single debug transfer of an ‘inspect’ command.
The Debug Output stream though is, of course, a stream so the length doesn’t get truncated.
