Debug works fine, Relase has problems
I have been messing with my webserver project and it has been working fine. This whole time i have been messing with it i have been in debug mode. I just switched to release and tried it and it gets hosed up. Any ideas why this would be happening ?
Found the problem, shocked too.
It goes back to this thread about using Debug.Print
[url]http://www.tinyclr.com/forum/1/4128/#/1/[/url]
Some said that it was ok to keep them in there in release mode if want to. so being a bit lazy i did not put the following everywhere i wanted to see something
 #if DEBUG
 Debug.Print("bla..bla...bla...");
 #endif
Instead i just put Debug.Print(“bla…bla…bla…”);
So now i went to release mode and it got hosed up.
I then went back and used Wouter Huysentruit idea to put this in
 #if DEBUG
 #endif
Then i used Architect’s idea and added the method
static void DebugPrint(string text)
    #if DEBUG
                Debug.Print(text);
    #endif
Then changed all my Debug.Print’s to DebugPrint.
Now it works just fine in release mode.
That’s a bit odd; never had anything break in release because of a debug line. And Microsoft.SPOT does more than Debug so I’d pretty much always keep that using :wink:
