I incorporated the loading of the configuration in the main event timer:
Program.Mainboard.SetDebugLED(rbLedCoeur);
rbLedCoeur = !rbLedCoeur;
if ( rnCpt <1)
rnCpt++;
return;
if (rnCpt == 1)
LoadConfig(); /////////////////////////////////////////
Debug.Print("Config chargée");
rnCpt++;
Here the body of the method loadConfig:
private void LoadConfig()
string stFileName, stLine ="";
StreamReader oStream;
if (sdCard.IsCardInserted == false)
Debug.Print("SdCard absente. La configuration par defaut sera appliquee");
return;
stFileName = sdCard.GetStorageDevice().RootDirectory + "\\ConfigHydra.ini";
oStream = new StreamReader(stFileName);
stLine = oStream.ReadLine(); //Problem this line /////////////////////////
oStream.Close();
oStream.Dispose();
If the line: stLine oStream.ReadLine = () is commented, I get the following debug trace
in VS2010 :
Found debugger!
Create TS.
Loading start at 2018f198, end 201bc4dc
Assembly: mscorlib (4.2.0.0) Assembly: Microsoft.SPOT.Native (4.2.0.0) Assembly: Microsoft.SPOT.Hardware (4.2.0.0)
Assembly: Microsoft.SPOT.Graphics (4.2.0.0) Assembly: Microsoft.SPOT.TinyCore (4.2.0.0)
Assembly: Microsoft.SPOT.IO (4.2.0.0) Assembly: System.IO (4.2.0.0) Assembly: Microsoft.SPOT.Hardware.Usb (4.2.0.0)
Assembly: Microsoft.SPOT.Hardware.SerialPort (4.2.0.0) Assembly: Microsoft.SPOT.Touch (4.2.0.0)
Assembly: Microsoft.SPOT.Ink (4.2.0.0) Assembly: Microsoft.SPOT.Hardware.PWM (4.2.0.1)
Assembly: Microsoft.SPOT.Hardware.OneWire (4.2.0.0) Assembly: System.Xml (4.2.0.0)
Assembly: Microsoft.SPOT.Time (4.2.0.0) Assembly: Microsoft.SPOT.Net (4.2.0.0)
Assembly: System (4.2.0.0) Assembly: Microsoft.SPOT.Net.Security (4.2.0.0)
Assembly: System.Net.Security (4.2.0.0) Loading Deployment Assemblies.
Attaching deployed file.
Assembly: GHI.OSHW.Hardware (4.2.5.0) Attaching deployed file.
Assembly: Gadgeteer (2.42.0.0) Attaching deployed file.
Assembly: System.Http (4.2.0.0) Attaching deployed file.
Assembly: GTM.GHIElectronics.SDCard (1.1.2.0) Attaching deployed file.
Assembly: GTM.GHIElectronics.Extender (1.1.2.0) Attaching deployed file.
Assembly: Test (1.0.0.0) Attaching deployed file.
Assembly: GHIElectronics.Gadgeteer.FEZHydra (1.1.3.0) Resolving.
GC: 1msec 395304 bytes used, 5895828 bytes available
Type 0F (STRING ): 24 bytes
Type 15 (FREEBLOCK ): 5895828 bytes
Type 17 (ASSEMBLY ): 30024 bytes
Type 1E (BINARY_BLOB_HEAD ): 365184 bytes
GC: performing heap compaction…
Ready.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managé) : ‘C:\Program Files\Microsoft .NET Micro Framework\v4.2\Assemblies\le\mscorlib.dll’ chargé, symboles chargés.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managé) : ‘C:\Program Files\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Native.dll’ chargé, symboles chargés.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managé) : ‘C:\Program Files\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.dll’ chargé, symboles chargés.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managé) : ‘C:\Program Files\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Graphics.dll’ chargé, symboles chargés.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managé) : ‘C:\Program Files\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.TinyCore.dll’ chargé, symboles chargés.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managé) : ‘C:\Program Files\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.IO.dll’ chargé, symboles chargés.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managé) : ‘C:\Program Files\Microsoft .NET Micro Framework\v4.2\Assemblies\le\System.IO.dll’ chargé, symboles chargés.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managé) : ‘C:\Program Files\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.Usb.dll’ chargé, symboles chargés.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managé) : ‘C:\Program Files\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.SerialPort.dll’ chargé, symboles chargés.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managé) : ‘C:\Program Files\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Touch.dll’ chargé, symboles chargés.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managé) : ‘C:\Program Files\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Ink.dll’ chargé, symboles chargés.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managé) : ‘C:\Program Files\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.PWM.dll’ chargé, symboles chargés.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managé) : ‘C:\Program Files\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.OneWire.dll’ chargé, symboles chargés.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managé) : ‘C:\Program Files\Microsoft .NET Micro Framework\v4.2\Assemblies\le\System.Xml.dll’ chargé, symboles chargés.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managé) : ‘C:\Program Files\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Time.dll’ chargé, symboles chargés.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managé) : ‘C:\Program Files\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Net.dll’ chargé, symboles chargés.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managé) : ‘C:\Program Files\Microsoft .NET Micro Framework\v4.2\Assemblies\le\System.dll’ chargé, symboles chargés.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managé) : ‘C:\Program Files\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Net.Security.dll’ chargé, symboles chargés.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managé) : ‘C:\Program Files\Microsoft .NET Micro Framework\v4.2\Assemblies\le\System.Net.Security.dll’ chargé, symboles chargés.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managé) : ‘C:\Program Files\GHI Electronics\GHI OSHW NETMF v4.2 SDK\Assemblies\le\GHI.OSHW.Hardware.dll’ chargé
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managé) : ‘C:\Program Files\Microsoft .NET Gadgeteer\Core\Assemblies.NET Micro Framework 4.2\le\Gadgeteer.dll’ chargé, symboles chargés.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managé) : ‘C:\Program Files\Microsoft .NET Micro Framework\v4.2\Assemblies\le\System.Http.dll’ chargé, symboles chargés.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managé) : ‘C:\Program Files\GHI Electronics\GHI .NET Gadgeteer SDK\Modules\SDCard\NETMF 4.2\le\GTM.GHIElectronics.SDCard.dll’ chargé, symboles chargés.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managé) : ‘C:\Program Files\GHI Electronics\GHI .NET Gadgeteer SDK\Modules\Extender\NETMF 4.2\le\GTM.GHIElectronics.Extender.dll’ chargé, symboles chargés.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managé) : ‘C:\Program Files\GHI Electronics\GHI .NET Gadgeteer SDK\Mainboards\FEZHydra\NETMF 4.2\le\GHIElectronics.Gadgeteer.FEZHydra.dll’ chargé, symboles chargés.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managé) : ‘E:\Dev\DomLaMade\ModulesNetMf\Test\Test\bin\Debug\le\Test.exe’ chargé, symboles chargés.
Le thread ‘’ (0x2) s’est arrêté avec le code 0 (0x0).
Using mainboard GHI Electronics FEZHydra version 1.2
Program Started
Config chargée
Le thread ‘’ (0x3) s’est arrêté avec le code 0 (0x0).
If the line:
stLine oStream.ReadLine = () is executed
I get the following debug trace, after being forced to do a manual reset of the Hydra card while VS 2010 trying to start the debugger:
Create TS.
GC: 1msec 395328 bytes used, 5895804 bytes available
Type 15 (FREEBLOCK ): 5895804 bytes
Type 17 (ASSEMBLY ): 30036 bytes
Type 1E (BINARY_BLOB_HEAD ): 365196 bytes
Ready.
Program Started
Config chargée
Seen between the two debug traces the beginning of the sequence (Found debugger!) is not displayed when I have to do a manual reset on the Hydra card.
Moving the code will enable debugging but it hides a problem between VS2010 and Hydra card with firmware 4.2.5.0
