DateTime trouble
Hi all,
Lets consider the following code snippet which calculates the span of time
between two interrups (Panda II, newest SDK):
    //Version 1
    private void InterruptHandler(uint Port, uint State, DateTime time)
      try
        unchecked
           _NewTicks = Utility.GetMachineTime().Ticks;
           _Duration = (int)(_NewTicks - _StartTicks);
          _StartTicks = _NewTicks;
      catch
This code is completely independent from all time changes (e.g. Utility.SetLocalTime/TimeService.SetTimeZoneOffset),
but Utility.GetMachineTime().Ticks is the timestamp at processing time, not the interrupt time.
Using the time parameter will be more accurate , so lets try:
    // Version 2
      try
        unchecked
           _NewTicks = time.Ticks;
      catch
 The problem here: the code will fail if elsewhere  Utility.SetLocalTime/TimeService.SetTimeZoneOffset will be used, so lets try:
    // Version 3
      try
        unchecked
           _NewTicks = Utility.GetMachineTime().Ticks - (DateTime.Now - time.Ticks) .Ticks;
      catch
 Provided that execution time of Utility.GetMachineTime().Ticks and DateTime.Now is a constant value, _Duration will be accurate.
 But this code fails too, e.g TimeService.SetTimeZoneOffset(120) will affect DateTime.Now , but not the time parameter.
 ( DateTime.Now - time.Ticks is about "02:00:00.000xxx") .
 Please note , both DateTime.Now and time are marked as local time (DateTimeKind = Local).
 Why is time parameter's time always UTC? And if that is correct (i guess it is) , why DateTimeKind is not Utc?
 Is there a property ("offset")  inside the framework  , so we can count back machine ticks from time parameter' ticks  :  MachineTtick= time.Ticks - "offset" ?
 It would spare me some work to follow time changes / time zones / daylight-saving time..
 Thank you very much in advance
sorry,
Version 3 should be:
_NewTicks = Utility.GetMachineTime().Ticks - (DateTime.Now - time) .Ticks;
Have you try using
DateTime.UtcNow
