DateTime loss
Pick a firmware version and stick to it. 4.2 is the newest option, so I’d suggest doing that.
Apply the FULL update to all portions including the tinybooter. Use the Hydra updater to do it all
Create a new project, that just flashes the onboard LED. Deploy.
I don’t have a T35 but you should see boot messages on it (from what I know) and then your LED should start flashing.
If 4.2 works I will stick to it, I just reverted to do a full update from a working base.
I did not get any boot message the screen does not change during reboot, but board and deploying work since I let the LED blink every second.
After trying around for a while I managed to get everything working! It even looks like the update has solved the time loss problem.
Now I only need to wait for the touch to be added…any news on that since the last message in the beta-forum regarding the touch on
the hydra is over a month old?
I’m glad you were able to solve the issue. For the Touch issue here is a link to managed code to operate the touchscreen on Hydra http://www.tinyclr.com/codeshare/entry/563 . It does not have calibration so that will need to be added.
