Hi guys!
I’m going to start an home automation project.
The Display T35 will be used for controlling the whole system so I’d like to find a cover plate or something to install the display on a wall.
Do you know if there is something available on the market?
Any idea to solve the problem?
Personally, I think I’d go with the CP7. A little more expensive but it’s capacitive touch and it’s easy to make it look polished. You just find a box and cut a hole in it. The CP7 has double stick tape all around the edges that adhere/seal it to the box. That being said I think removal is never an option once it’s mounted…
Hi guys!
I’m not so good in cutting holes, so probably a 3d printer is definitely what I need…
I’m going to look the specs of the cp7.
Thank you for your answers and have a happy new year!
@ SteZab - You could also have something laser-cut, using a service such as Ponoko. There are already a couple of designs up there for Gadgeteer that include the T35, so you could modify one of those to suit your needs:
