How do you count running Threads?
This technique won’t be accurate. For example, how many running threads do you expect to see in the following example? 3 (main thread + 2 threads started by timer)? No! You get 5 or 7 (or maybe even more) based on how much time has elapsed from the start. And I guess there will be other cases where your suggested technique won’t be accurate.
Public Sub ProgramStarted()
a.Start()
b.Start()
End Sub
Dim WithEvents a, b As New Timer(5000)
Dim t1, t2 As Thread
Private Sub a_Tick(timer As Timer) Handles a.Tick
If t1 IsNot Nothing AndAlso t1.IsAlive Then t1.Abort()
t1 = New Thread(Sub()
For i = 1 To 5000
Debug.Print("1: " & i.ToString())
Next
End Sub)
t1.Start()
End Sub
Private Sub b_Tick(timer As Timer) Handles b.Tick
If t2 IsNot Nothing AndAlso t2.IsAlive Then t2.Abort()
t2 = New Thread(Sub()
For i = 1 To 5000
Debug.Print("2: " & i.ToString())
Next
End Sub)
t2.Start()
End Sub
Also, you have mentioned “thread safe global var”, are you referring to atomic operations? If so, what’s the point of those if there is no real multithreading in NETMF? Only one single thread can run at a time.
[quote]Also, you have mentioned “thread safe global var”, are you referring to atomic operations? If so, what’s the Also, you have mentioned “thread safe global var”, are you referring to atomic operations? If so, what’s the point of those if there is no real multithreading in NETMF? Only one single thread can run at a time.
[/quote]
Bzzzzzzzzz
MF implements a 20ms time slice when multiple threads are CPU ready. A running thread can get suspended at any time, and another thread can run. that is why locking and mutexs are implemented I’m MF.
one of the best features of MF is that it supports true multi threading!
@ Mike
When I say there is “no real multithreading”, I mean that parallel execution is not possible. At one point in time [em]only one thread[/em] will be doing something, while all the other threads will be waiting.
I did some reading and some testing. One thing I was wrong about was that something like this [em]a += 1[/em] is not and indivisible instruction.
I have tried a sample code suggested by MS to test thread-safe way to increment and decrement an integer value. But strange thing happens when I set to create more instances of CountClass (e. g. 90k instead of 10k). I get “SafeCountInstances: -4” instead of expected zero value. Is Interlocked class not 100% thread-safe?
Partial Public Class Program
Dim WithEvents MyTimer As New Timer(3000, Timer.BehaviorType.RunOnce)
MyTimer.Start()
Debug.Print("Program Started")
End Sub
Private Sub MyTimer_Tick(timer As Timer) Handles MyTimer.Tick
Dim thread1 As New Thread(AddressOf ThreadMethod)
Dim thread2 As New Thread(AddressOf ThreadMethod)
thread1.Start()
thread2.Start()
thread1.Join()
thread2.Join()
' Have the garbage collector run the finalizer for each
' instance of CountClass and wait for it to finish.
Debug.GC(True)
GC.WaitForPendingFinalizers()
Debug.Print("UnsafeInstanceCount: " & CountClass.UnsafeInstanceCount.ToString() & _
vbCrLf & "SafeCountInstances: " & CountClass.SafeInstanceCount.ToString())
End Sub
Shared Sub ThreadMethod()
Dim cClass As CountClass
For i As Integer = 1 To 1000
cClass = New CountClass()
Next
End Sub
End Class
Public Class CountClass
Shared unsafeCount As Integer = 0
Shared safeCount As Integer = 0
Shared ReadOnly Property UnsafeInstanceCount As Integer
Get
Return unsafeCount
End Get
End Property
Shared ReadOnly Property SafeInstanceCount As Integer
Get
Return safeCount
End Get
End Property
Sub New()
unsafeCount += 1
Interlocked.Increment(safeCount)
End Sub
Protected Overrides Sub Finalize()
unsafeCount -= 1
Interlocked.Decrement(safeCount)
MyBase.Finalize()
End Sub
End Class
