I am struggling to find some solid documentation on how to use a wiinForms GUI while real time debugging so I can fine tune my motor without having to redploy every time I want to input a different parameter.
Does anyone have some advice, example code, or good links? The default emulator GUI when creating a NETMF window app is much different than I am used to as I can’t find a “Form Design,” view.
1.create an conection of uarT
2.set baud rate
3.on uart send data you want to debug
3.create form to listen uart (throught Usb ftdrl…)
also you can use arduino ide serial monitor or tera term
I’ll take a look at it but it looks overly complicated. I just need basic code for a windows form in NETMF. Is there a form design window like in regular .net where you can drag and drop controls?
i will create one example for you with tinyclros
and one winform C# also you need an external usb uart to act as communicator between pc with winform and board
with schema and example i will explain how
from board you will receive info to winform and
how from winform you will send info to board
and i belive example will be enought for you to understand
using the debugger you can set a breakpoint and stop execution. Then you can use the debugger to change the value of a tuning variable in memory. You can then continue execution with the changed variable.
usb that you are using is for deploy upload and debug with visual studio if i understand and it can not be used to communicate with outer interface
in your case to see values and to send values (Parameters that your application can use for their purpose if i am not wrong)
For example you want to click button on winform
board will set led on when you click another button led will be off
or from analog pins when you turn potentiometer that value you want to see on winform
You are correct. I was envisioning doing this though the debug interface but I guess that wouldn’t make sense since that code is actually deployed to the uC and I wouldn’t want to deploy winForms to it.
Do you have some example code for me? I think I am beginning to understand what needs to be done but not how to implement it.
The interfacing part is where I am confused.
So I would deploy my normal NETMF code then create a separate project in .Net to make the GUI, then use serial communication? What pins do I need to connect for that and to what?
