Main Site Documentation
Control Color LCD
#1
Hello everyone,
i was just wondering how hard would it be to control a color lcd like this.
http://www.dealextreme.com/details.dx/sku.36475
they are cheap and you can now also buy the USBizi chip so you can then almost make a dedicated project without needing to buy a new fez.
#2
Where is the datasheet of that display? :wink: Just looking at the picture wouldn’t help :frowning:
Have you seen this (website is down but will be up soon)
http://www.fezzer.com/project/60/24-tft-lcd-screen-module/
GHI is adding a parallel interface so if that display uses 8-bit parallel interface then you can use it easily. Search the forum. There was a long topic on this few days ago
#3
Hi all this info I can find is this.
Screen LCD:
  • Model: FTP280P04N
  • Model FPC (Flexible Printed Circuit): FPC-FTP280P04N-01
  • Length of pliege FPC: 27.80
  • Driver IC: ILI9325
  • Crystal TFT: THE GIP P4928QC1-1.0
  • So large of screen: 2.8 "
  • Retroiluminación (Backlight): White, 4 LED Chips in parallel
  • Description: In the base of 280C05 for IC and LCD
  • I number of pixels: 240RGBx320
  • I number of Pins: 37
  • Type of Interface (): 16
  • Definition of the Pin Nº 1: DB0
  • Way and colors of screen (display): 262K TFT/Transmissive
  • Perspective of the direction: 12:00
  • Dimensions: 69.2 xs 50,0 xs 2.75
  • Active area: 57.6 xs 43.2
    http://dingoo-scene.blogspot.com/2009/04/dingoo-with-different-innards-emerges.html
and the driver datasheet ( ILI9325)
http://gravitech.us/MicroResearch/DevelTools/ARM/ILI9325_DriverChipDatasheetNEW.pdf
edit: datasheet says
MPU System Interface
ILI9325 supports three system high-speed interfaces: i80-system high-speed interfaces to 8-, 9-, 16-, 18-bit
parallel ports and serial peripheral interface (SPI). The interface mode is selected by setting the IM[3:0] pins.
Is this enough to figure it out?
i thought this would be a good schreen becouse its pretty easy to solder.
#4
The display on Fezzer that Gus mentioned is controled by the same ILI9325,so the driver will work.
Here is the link to the other “long topic”:
http://www.tinyclr.com/forum/8/1396/
Cheers,
V
#5
Cool thanks.
