In the universe NETMF / GHI is there any function equal to constrain the arduino?
Thanks,
Alexandre
From Brazil
Thanks,
Alexandre
From Brazil
What does this function do?
constrain function make this:
constrain(x, a, b)
Description
Constrains a number to be within a range.
Parameters
x: the number to constrain, all data types
a: the lower end of the range, all data types
b: the upper end of the range, all data types
Returns
x: if x is between a and b
a: if x is less than a
b: if x is greater than b
You can write this function easily.
Eric
Erick, see my function:
static int constrain(int x, int a, int b)
int max = System.Math.Max(a, b);
int min = System.Math.Min(a, b);
int result = 0;
if (x > min && x < max)
result = x;
else if (x < min)
result = min;
else if (x > max)
result = max;
return result;
You only need to check if it is less than a or greater than b. You can also eliminate Min/Max dependency by comparing a and b.
You can implement this function as an extension for each numeric data type like so…
// Required for NETMF to recognized extension methods
namespace System.Runtime.CompilerServices
[AttributeUsage (AttributeTargets.Assembly | AttributeTargets.Class | AttributeTargets.Method)]
public sealed class ExtensionAttribute : Attribute { }
public static class Extensions
public static int Constrain (this int x, int a, int b)
return x < a ? a : (x > b ? b : x);
public static double Constrain (this double x, double a, double b)
// continued... define an extension for all numeric data types
@ ransomhall
given a < b,but not in general case
I got too excited about the “one liner” So what happens in the arduino function when a>b? The help link above does not provide details in this case. I’m not sure what the most logical answer would be. switch a & b values?
