I just went to assemble using my CAD software a custom board to the Cerbuino and I spotted that the pitch is wrong.
The pitch is 2.45mm when I measure it and it should actually be 2.54mm (0.1")
The pitch on the PCB footprint is correct. Seems to just be the model that is wrong.
Luckily the holes align so I should be able to use the model in the enclosure design and have things align properly.
Just wanted to bring it to attention in case anyone else is working with the 3D models.
The image shows the error when I align the mounting holes.
PS. I also noticed that the pitch on the Gadgeteer pins is also wrong. They show up as 1.2mm putch with 4.88 from pin 1 to pin 5 when it should be 1.27mm pitch and 5.08mm from pin 1 to pin 5. Interestingly, the pich on the PCB footprint is correct. Same as the other observation, the 3D model of the connector is wrong.
