I’m trying to connect my fez panda in order to perform a get http request that I need but it seems that it is not working and I don’t know if maybe I need to change something in my router configuration.
What I did is:
Configured my vonets wifi bridge to be connected to my wifi connection
Connect the wifi bridge usb to my laptop and the rj45 to the fez connect shield
Run this example code from internet of things book:
Then it returns a null for GHI_ip and if I ping the 192.168.1.222 ip that ping works randomly (it depends of the execution or if I change the ip the ping works for both of them and I don’t undertand). Does anyone know what is the problem?
This is a real old, long discontinued, product and I personally don’t remember much. But I really want to see this running TinyCLR. There are thousands of these devices floating around.
Also, where did you get the MAC address? Completely random, or something that you know? It is a critical part of the physical network layer, if you have a conflict on your network then you’ll struggle to get any comms working
Thanks Brett, but I tried with other projects and I always have the same problem. Using this dinamic dns I get this error:
FEZ Connect Driver : Initializing network…
#### Exception System.Exception - 0x00000000 (1) ####
#### Message: Dhcp Client Timeout
#### GHIElectronics.NETMF.Net.NetworkInformation.Dhcp::GetDhcpLease [IP: 00aa] ####
#### GHIElectronics.NETMF.Net.NetworkInformation.Dhcp::EnableDhcp [IP: 004a] ####
#### JDI.NETMF.Shields.FEZConnect::InitializeNetwork [IP: 002b] ####
#### FEZConnectDriver.Program::InitializeNetwork [IP: 0015] ####
#### FEZConnectDriver.Program::Main [IP: 0092] ####
A first chance exception of type ‘System.Exception’ occurred in GHIElectronics.NETMF.W5100.Dhcp.dll
FEZ Connect Driver : Network ready.
IP Address: 0.0.0.0
Subnet Mask: 0.0.0.0
Default Getway: 0.0.0.0
DNS Server: 0.0.0.0
Free mem : 40788
And this is why I think that maybe I have a problem with my router configuration or something like that. Can I connect the fez to the router using a rj45 cable? Although I disabled my laptop connections and I was able to connect using the wifi bridge.
so when connected to the wifi device you aren’t getting DHCP leased addresses. Certainly sounds like a config issue on the bridge - proven when you connect direct to the router. Great to know your code works, right? Now all you need to do is track down if you can get the bridge to pass DHCP packets
