Atlas Scientific makes a pH probe kit that communicates with the MCU using a simple serial protocol. A little pricey, but it works great. I use it in my commercial applications.
Hi thnx for the reactions the problem is that the sensor is just for a hobby project so that is why the dfrobot sensor is a great option. But why could it not work ? i have seen that the gadgeteer sockets have analog input and 5v voltage available via an extender is it not just connecting the data wire to a analog connector ?
Analog inputs have different ratings, one can withstand 3.3V max, another 5V max and so on. I think I have not seen any GHI mainboard that has analog input rated to work with 5V.
@ WE - pay attention to this. Do not connect 5V to any Analog input on a GHI board. While they may (or may not) be 5V “tolerant”, it’s not a good idea to prove that tolerance.
However, you should be able to wire the signal line on the probe to any analog input on a gadgeteer socket. You’ll need some pH calibration solutions to calibrate it. ph 4 and 10 standards will do the trick. Also get a ph 7 standard to use for error checking. You’ll always see some drift around ph 7, but it should be within 5% if the quality of your probe is at all decent. Over time that calibration will drift as probe characteristics change, so always use the 4, 7, and 10 solutions to check. If it’s outside 5%, it’s time to recalibrate.
Looks like the Atlas probe comes with the standards.
Get one of the terminal block or breadboard gadgeteer modules and you won’t even need to solder.
