For some reason the debugger will not attach to a running platform, or rather it does attach but you cannot breakpoint etc, similar to if the symbols were invalid.
E.g. from an app, Run it on the device, Detach and then use the Debug window to Attach back to the device. At this point you can no longer breakpoint, despite not rebuilding the code in between.
A little bit direct Architect. If I am asking, it’s because I don’t see the Attach to process choice in debug tab on my version not because I am lazy…
Sorry, that was not my intention to offend you. Been awhile since I looked at the Express edition and that would have been my first thing to do - “to try it”.
@ Michael Kaufman - I was able to reproduce the issue on our boards as well as the boards from other manufacturers. So it seems to be an issue with NETMF. I would create an issue here: https://netmf.codeplex.com/workitem/list/basic
Is there any changes regarding possibility to connect to running code and set breakpoints?
I have tried it with VS2013 Community and latest pre-release 2015 and it seems it is still not possible. It will be enough just to place breakpoints in own code not necessary in GHI or MS libraries but it still complains that symbols are not possible to upload and especially that GHI modules doesn’t include .pdb symbol files (there are only .pdbx files).
