Can anyone suggest if I can connect an AMO LED screen such as
P0430WQLC-T
Can be connected to a FEZ cobra? It has serial or parallel connections, but seems to want 8 lines for each of the RGB channels and the cobra seems to have 5 on each?
Thanks, james
if display requires eight and you have less per color then use the bits you have as the high order bits and ground the low order bits.
I’m with you - good stuff
