Can I connect 18 Raptor Mainboard port to port 7 Maynboard Cerberus and use the Y GPIO interface?
I read it as he wants to connect Port 18 of his Raptor to Port 7 of his Cerberus…
GPIO pins are GPIO pins. You can connect the mainboard together using a GPIO socket, but you will have to write the communications protocol between the board. If you want to share information, I would suggest using a serial protocol such as UART.
okey. but how connect? Example: Raptor: socket 4 → Cerberus: socket 2.? (serial port 2)
I need to transfer data from cerberus
