Hello,
after developed a driver (http://unfc.codeplex.com/) for this NFC board…
http://www.elecfreaks.com/store/rfidnfc-breakout-board-p-519.html?zenid=jbh41fhq5brtouj109898179p2
…that works well on Netduino board using wires, I want to connect the same board to a FEZ Hydra using socket.
For the connection of a non-gadgeteer board to a gadgeteer board I saw that there are some possibilties.
They are the following :
- Breakout Module Set (https://www.ghielectronics.com/catalog/product/405) : in this case I have to use an IDC cable to connect to the FEZ Hydra and wires for the NFC board (are cables included into the package ?);
- G-Plug Module (https://www.ghielectronics.com/catalog/product/430) : in this case I no need IDC cable because the connector goes on the FEZ Hydra directly and I have to use wires for the NFC board connection;
- Extender Module (https://www.ghielectronics.com/catalog/product/273) : in this case I need an IDC cable for FEZ Hydra connection and wires for the NFC board;
I think that the better solution is G-Plug Module for my porpouse.
Is it right ?
Any suggestions ?
Paolo.
