Connect 2015
If you’re not watching, you should be:
http://channel9.msdn.com
Cool use of IoT by the folks at GoJo, using motion tracking to monitor traffic in patient rooms in a healthcare setting, and connected hand sanitizer dispensers to monitor compliance with hand cleaning requirements.
While the “cows in heat” scenario highlighted last year was arguably funnier, this is an IoT scenario that has the potential to save lives. Very cool.
@ andre.m - The live stream is past the point where they first discussed the GoJo solution. There also looks to be a breakout later in the day that’ll go into more detail.
Most interesting announcement from an IoT perspective: Announcing the VS GDB Debugger extension - C++ Team Blog
Debug native code on a microcontroller directly in VS, without buying VisualGDB? Yes, please.
