i’ve got personal project i’m working on that uses both and arduino and cerbuino board.
the arduino drives the motors and the cerbuino acts as the brains. I need to cerbuino to be able communicate with the arduinio/motor controller. What’s the best way to do this you think?
Can these things comunicate usb-to-usb? (i don’t have any serial adapters/modules).
What about the idea of using a pin to write a value of 1-5 (Foward, backward, left, right, stop)?
USB->USB isn’t going to be ideal. I believe others have used serial in the past. All you would need is to wire the RX->TX & TX->RX & GND->GND then go about parsing the data.
I’ve done this in another project and it works great if you just need a very simple 1-5 value. You would need 3 pins, though, not just 1 to get that range. I suspect that you actually need more data than that thought (i.e. speed + direction). But if just a 1-5 value will work then this is a very simple solution.
Thanks Ian…i need to process this: “All you would need is to wire the RX->TX & TX->RX & GND->GND then go about parsing the data.”
I don’t currently have any .net gadgeteer serial modules or arduino serial shield.
Any samples or reading materials you recommend on how to go about doing the above?
You don’t really need a shield. Both boards know how to speak the serial language. You just need to connect the right pins. For the arduino header this is going to be D0 (RX) & D1 (TX). Since the Cerbuino has the Arduino header the pins are the same there also. So, connect (with a wire)
D0 → D1
D1 → D0
GND → GND
There are examples all over the place including the Tutorials under support on how to use the SerialPort class to receive the messages. Good luck!
