I’m working on writing code for a Mountaineer Eth Mainboard. I am programming 3 RGB LED’s and a switch, as well as socket communications. Im having problems with the usings:
using System.Linq;
using System.Text.RegularExpressions;
using System.Net.NetworkInformation;
the bold parts above are giving me errors that they do no exist but i’ve used them in several other applications. Are they not working because im using the Gadgeteer framework?
Also, to change the color of the LED’s im using the GPIO pins which are enumerated as such:
public class Socket1
public const Cpu.Pin BluePinA = (Cpu.Pin)59; //blue LED pin
public const Cpu.Pin GreenPinA = (Cpu.Pin)49; //green LED pin
public const Cpu.Pin RedPinA = (Cpu.Pin)48; //red LED pin
Since they’re interpreted as constants how do i “turn on/off” the Pins to change the color. I’m still pretty new to C# so im sure that im missing something.
@ UofLTCI - The micro framework is a very cut down version of it’s big brother so you cant use alot of the full framework namespaces hence why your using’s are causing a problem.
To add to what Justin said, those namespaces are in the full .NET framwork, but not in the micro framework. That’s one reason they call it micro I would suggest doing some homework on what is in NETMF, and starting with some sample code first.
