I have a Cobra right out of the box. Nothing connected except USB and external power. I can’t get IO21 signal to pullup. No issue with other IO’s.
Are all IO’s tested before shipping? Is IO21 reserved for something not documented?
Thanks -AP
Thanks -AP
It looks like IO21 is used for EMX / Cobra board detection it has a 10k pulldown so the software knows whether its a lone EMX module or if its mounted to the Cobra…
I should imagine it is documented somewhere…
Cheers Ian
Please check schematics http://www.tinyclr.com/downloads/Cobra/FEZ%20Cobra_sch.pdf
This is not documented beside schematics but we use this in our libs to detect Cobra vs EMX DevSys if necessary…as a future need
Hi everyone
Does it mean that we should not reuse IO21 for an other purpose? Should we keep it as a GHI reserved pin?
I’ve just received my two EMX modules and start to write my schematic for a custom PCB. This post is therefore very relevant to me.
You can use it
Hi all,
Let me pull this topic on top of the list for a quick question : So as IO21 is pulled down to 10k on the Cobra, does it mean that it is reserved and unsable if the EMX is mounted on the Cobra ?
Thanks.
Stephan.
I believe this means you can use it if you want to, but it WILL be pulled down and you can’t change that.
