I would like to use the Interface to the SD-Card, but I don’t succeed.
Both the funtion in the …FEZCobraII namespace and in the GHI.Hardware.Storage namespace lead to the same result.
Code:
SDCard sd = new SDCard();
#### Exception System.InvalidOperationException - CLR_E_INVALID_OPERATION (1) ####
#### Message:
#### GHI.IO.Storage.SDCard::NativeConstructor [IP: 0000] ####
#### GHI.IO.Storage.SDCard::.ctor [IP: 0017] ####
#### SDTestCobra.Program::ProgramStarted [IP: 000b] ####
What I’m doing wrong ?
What should I do best ?
thx a lot.
Michael
Now, I use following code…
Mainboard.SDCardMounted += Mainboard_SDCardMounted;
Mainboard.SDCardUnmounted += Mainboard_SDCardUnmounted;
if (Mainboard.IsSDCardInserted)
if (Mainboard.IsSDCardMounted)
StorageDevice sd = Mainboard.SDCardStorageDevice;
if (sd.Volume.IsFormatted)
string rootDirectory = sd.RootDirectory;
string[] files = Directory.GetFiles(rootDirectory);
string[] folders = Directory.GetDirectories(rootDirectory);
Debug.Print("Files available on " + rootDirectory + ":");
for (int i = 0; i < files.Length; i++)
Debug.Print(files[i]);
Debug.Print("Folders available on " + rootDirectory + ":");
for (int i = 0; i < folders.Length; i++)
Debug.Print(folders[i]);
In this case I can read the content of the card. But the events for insert an remove the are not fired.
I will looking for the reason about this.
If someone knows about this can write a message.
Thx a lot.
Michael
@ MHSchmidt - Which events are you referring to? Mainboard_SDCardMounted and Mainboard_SDCardUnmounted?
Yes, I can insert and remove but nothing happens.
I expect that the function is called.
Thx.
@ MHSchmidt - Are there other mass storage drives that you can try?
Yes, I have tried it with USB.
The insert event is fired and worked fine, but when I remove the stick an exception occured.
see other post.
Thx.
