I am using the Eagle pcb file to create a custom pcb using the G120 module.
Is there a partlist or bill of materials for the cobra II boards? I need to find the ethernet jack, the usb client jack and the SD memory card socket that are used on this board.
thanks
You could use any device that would suit your board or what you can find in the local market.
For example, on a custom G120 board I used a MicroSD card instead of full sized SD and a standard type B for the USB interface.
Same would apply for the Ethernet but I didn’t have that as I was using WiFi.
thanks. I was hoping to find part numbers for the actual parts used on the board to save time on creating components in Eagle.
