I have problem with my cerberus on Windows 8, it helps to use external power and hub usb … but sometimes ! On my hub only few ports permits to use board. Why ? Ports are différents ? No ! I could only see some works and some doesn’t !
If you could try with hub usb, with external power. Idealy, find a Windows 7 computer 8)
At the point I pressed reply … I had plugged into a different port on my usb hub and windows popped up and installed the driver. The device appeared in VS … looked great and then it disappeared …
Windows 8 is not a problem in general. I mostly use Windows 8.1 (update) x64 computers.
But when ever possible I use USB 2.0 ports and an extra power supply.
Once I had a similar problem, but reinstalling the SDK (and with it the drivers) solved the issue. Don’t forget to reboot after uninstalling the SDK.
Windows keep cycling the message USB device not recognised, so I don’t think the cobra is dead, just windows does not appear to have the correct driver? When I tried a different USB plug windows detected and installed the device driver, it appeared in VS … But shortly afterwards dropped out.
Hi Dave,
I have done the manual task with teraterm. Cobra still connected. When I now use fez config to update sdk … it does not list any options; so browse to fimrwares … there are 3xhex files … config, firmware and firmware2 … which do I select?
I was going to say, don’t connect through a HUB, connect direct. I’ve found that you can debug through a hub no problem but firmware updates have only been reliable on direct USB ports.
