I am getting the following in the output window when I try to deploy an updated app.
The only change is the inclusion of a 1MB bitmap file in the resources but the final size is still well within the G120’s capability.
I have the module programmed with the latest firmware so not sure what to make of the messages below.
Found debugger!
Create TS.
Loading start at a0e85768, end a0e9cec4
Assembly: mscorlib (4.2.0.0) Assembly: Microsoft.SPOT.Native (4.2.0.0) Assembly: Microsoft.SPOT.Hardware (4.2.0.0)
Assembly: Microsoft.SPOT.Hardware.PWM (4.2.0.1) Assembly: Microsoft.SPOT.Security.PKCS11 (4.2.0.0)
Assembly: System.Security (4.2.0.0) Loading Deployment Assemblies.
Attaching deployed file.
Assembly: GHI.Hardware.G120 (4.2.10.0) Attaching deployed file.
Assembly: Microsoft.SPOT.Net.Security (4.2.0.0) Attaching deployed file.
Assembly: Microsoft.SPOT.Touch (4.2.0.0) Attaching deployed file.
Assembly: GHIElectronics.NETMF.Glide (0.1.0.6) Attaching deployed file.
Assembly: GHI.Premium.Net (4.2.10.0) Attaching deployed file.
Assembly: MicroXBee (10.11.8.1) Attaching deployed file.
Assembly: GTM.GHIElectronics.Display_T43 (1.0.1.0) Attaching deployed file.
Assembly: Microsoft.SPOT.Net (4.2.0.0) Attaching deployed file.
Assembly: System.Net.Security (4.2.0.0) Resolving.
Assembly: Microsoft.SPOT.Touch (4.2.0.0) needs assembly 'Microsoft.SPOT.Graphics' (4.2.0.0)
Assembly: GHIElectronics.NETMF.Glide (0.1.0.6) needs assembly 'Microsoft.SPOT.Graphics' (4.2.0.0)
Assembly: GHIElectronics.NETMF.Glide (0.1.0.6) needs assembly 'System.Xml' (4.2.0.0)
Assembly: GHIElectronics.NETMF.Glide (0.1.0.6) needs assembly 'Microsoft.SPOT.Touch' (4.2.0.0)
Assembly: GHIElectronics.NETMF.Glide (0.1.0.6) needs assembly 'System.IO' (4.2.0.0)
Assembly: MicroXBee (10.11.8.1) needs assembly 'MicroIO' (10.11.8.1)
Assembly: MicroXBee (10.11.8.1) needs assembly 'Microsoft.SPOT.Hardware.SerialPort' (4.2.0.0)
Assembly: MicroXBee (10.11.8.1) needs assembly 'System.IO' (4.2.0.0)
Assembly: GTM.GHIElectronics.Display_T43 (1.0.1.0) needs assembly 'Gadgeteer' (2.42.0.0)
Assembly: GTM.GHIElectronics.Display_T43 (1.0.1.0) needs assembly 'Microsoft.SPOT.Graphics' (4.2.0.0)
Assembly: GTM.GHIElectronics.Display_T43 (1.0.1.0) needs assembly 'Microsoft.SPOT.TinyCore' (4.2.0.0)
Assembly: GTM.GHIElectronics.Display_T43 (1.0.1.0) needs assembly 'Microsoft.SPOT.Touch' (4.2.0.0)
Assembly: System.Net.Security (4.2.0.0) needs assembly 'System' (4.2.0.0)
Error: a3000000
The program '[17] Micro Framework application: Managed' has exited with code 0 (0x0).
Waiting for debug commands...
