Trying to load a Glide UI that uses a Slider control (vertical, if it makes a difference), and I’m getting a CLR_E_DIVIDE_BY_ZERO exception when loading the window, unless I remove the slider. Here’s the slider markup:
<Slider Name="speed" X="287" Y="34" Width="20" Height="200" Alpha="255" Direction="vertical" SnapInterval="10" TickInterval="10" TickColor="000000" KnobSize="20" Minimum="0" Maximum="100" Value="0"/>
and here’s the exception details:
#### Exception System.Exception - CLR_E_DIVIDE_BY_ZERO (1) ####
#### Message:
#### GHIElectronics.NETMF.Glide.UI.Slider::Init [IP: 00c5] ####
#### GHIElectronics.NETMF.Glide.UI.Slider::set_KnobSize [IP: 000a] ####
#### GHIElectronics.NETMF.Glide.UI.Slider::.ctor [IP: 005a] ####
#### GHIElectronics.NETMF.Glide.GlideLoader::LoadSlider [IP: 00fb] ####
#### GHIElectronics.NETMF.Glide.GlideLoader::GetComponent [IP: 00ad] ####
#### GHIElectronics.NETMF.Glide.GlideLoader::LoadWindow [IP: 00a9] ####
#### GHIElectronics.NETMF.Glide.GlideLoader::LoadWindow [IP: 000b] ####
Suggestions for troubleshooting?
