Hi, everyone!
I’m trying to work with the Internal File System of the ChipworkX (//NAND). Although I
can mount the internal File System as a new PersistentStorage instance, I was unable
to do much else…
I played with this for quite a while, and observed the following related problems:
(–> btw, upon receiving the ChipworkX, I immediately upgraded the Firmware. Took some time,
but quite educational for me, and very smooth. So, I thought that was not the problem…)
When I asked whether the Volume is Formated, the response was False. So, I thought this
was a bit unpromising… -
When I ran my code on the ChipworkX, I could confirm that there is in fact
a Directory under \ called \NAND, and could confirm that it is the root.
However, when I tried to change directories to NAND, by several methods
I got an IOException. ??? -
Not too surprisingly, attempts later on in the code (still in ), to create a StreamWriter instance (along with a new file) without switching directories
also generated an Exception, which expected, at that point. -
Also, an attempt to Format(0), while preserving the directory structure, was also unsuccessful…
(runs into an Exception). I tried that right before my attempt to change directories, but no luck.
Here is my code:
internalFS = new PersistentStorage("NAND");
internalFS.MountFileSystem();
// Here is where I get a 'False' regarding volume formatting:
Debug.Print("Internal File System Formatted? " + VolumeInfo.GetVolumes()[0].IsFormatted);
// Next, I just check to determine the current directory:
Debug.Print(Directory.GetCurrentDirectory()); // The current directory is /, so that seemed
// inconsistent with the False result
// regarding volume formatting...
// Next, I checked to confirm the root directory (\NAND):
Debug.Print(rootDirectory);
// Next, I checked for subdirectories of \:
string[] myDirectories = Directory.GetDirectories(Directory.GetCurrentDirectory());
foreach (string s in myDirectories)
Debug.Print(s);
// Next, I tried to change directories to the root (2 methods; both yield an Exception):
//Directory.SetCurrentDirectory( rootDirectory );
Directory.SetCurrentDirectory(@ "\NAND");
Either way I try it, this SetCurrentDirectory() request yields an IOException:
Exception System.IO.IOException - CLR_E_DIRECTORY_NOT_FOUND (1)
#### Message:
#### System.IO.Directory::SetCurrentDirectory [IP: 001c] ####
#### FileInputOutputOperationsEx.Program::Main [IP: 006d] ####
A first chance exception of type ‘System.IO.IOException’ occurred in System.IO.dll
An unhandled exception of type ‘System.IO.IOException’ occurred in System.IO.dll
BTW, if I try to Format(0) at //**, I also get an IOException…
The normal output, prior to the Exception, is below, and is pretty much as expected:
Internal File System Formatted? False
\NAND
\NAND
So, the ROOT definitely exists…I just am unable to set directories to it. Not surprisingly,
I cannot create a file in , so I did not include that code above.
This is my first time trying to access NAND, so…perhaps I am making a simple mistake,
somewhere?
Any advice about this would be very much appreciated!
– John
