Hi . I’m new with MF so maybe its a stupid question. I have found several similar posts and different solutions but they don’t seem to work for me.
I have ChipworkX Development System and I’m trying to sent a WebRequest .
My code looks like this, sipmle:
namespace MFHTTPTest
WebRequest request = WebRequest.Create(
"http://www.google.com");
WebResponse response = request.GetResponse();
Debug.Print(((HttpWebResponse)response).StatusDescription);
response.Close();
I’m getting exception:
#### Exception System.Exception - 0x00000000 (1) ####
#### Message: DNS server IP address was not found.
#### GHIElectronics.NETMF.Net.Dns::GetHostEntry [IP: 0038] ####
#### GHIElectronics.NETMF.Net.HttpWebRequest::EstablishConnection [IP: 00e1] ####
#### GHIElectronics.NETMF.Net.HttpWebRequest::SubmitRequest [IP: 0013] ####
#### GHIElectronics.NETMF.Net.HttpWebRequest::GetResponse [IP: 000c] ####
#### MFHTTPTest.Program::Main [IP: 000c] ####
But when I this code, that i found as example :
static public bool ethernet_event = false;
static public bool ethernet_last_status = false;
static public bool network_is_read = false;
static public ManualResetEvent NetworkAvailablityBlocking = null;
if (!Ethernet.IsEnabled)
Ethernet.Enable();
NetworkChange.NetworkAvailabilityChanged += new NetworkAvailabilityChangedEventHandler(NetworkChange_NetworkAvailabilityChanged);
NetworkInterface[] netif = NetworkInterface.GetAllNetworkInterfaces();
// Ethernet is always the first interface netif[0]
NetworkAvailablityBlocking = new ManualResetEvent(false);
if (!Ethernet.IsCableConnected)
Debug.Print("Cable is not connected!");
NetworkAvailablityBlocking.Reset();
while (!NetworkAvailablityBlocking.WaitOne(5000, false))
Debug.Print("Still waiting.");
break;
Debug.Print("Ethernet cable is connected!");
Debug.Print("Enable DHCP");
try
if (!netif[0].IsDhcpEnabled)
netif[0].EnableDhcp();// This function is blocking
netif[0].RenewDhcpLease();// This function is blocking
network_is_read = true;
Debug.Print("Network settings:");
Debug.Print("IP Address: " + netif[0].IPAddress);
Debug.Print("Subnet Mask: " + netif[0].SubnetMask);
Debug.Print("Default Getway: " + netif[0].GatewayAddress);
Debug.Print("DNS Server: " + netif[0].DnsAddresses[0]);
catch
Debug.Print("DHCP Faild");
Debug.Print("Test DNS");
try
IPHostEntry myIP = Dns.GetHostEntry("www.google.com");
if (myIP != null)
Debug.Print(myIP.HostName + ": " + myIP.AddressList[0].ToString());
catch
Debug.Print("Faild to Get the host entry of the FQN from DNS server!");
static void NetworkChange_NetworkAvailabilityChanged(object sender, NetworkAvailabilityEventArgs e)
if (e.IsAvailable)
if (Ethernet.IsCableConnected)
if (ethernet_last_status != true)
ethernet_last_status = true;
NetworkAvailablityBlocking.Set();
if (!WiFi.IsLinkConnected)
if (ethernet_last_status != false)
I’m getting successful response:
Enable DHCP
Network settings:
IP Address: 192.168.1.245
Subnet Mask: 255.255.255.0
Default Getway: 192.168.1.200
DNS Server: 87.253.32.130
Test DNS
www.google.com: 173.194.113.177
What can be the problem? Thanks In advance.
