I mentioned in my other questions about the ChipworkX Development System that if a USB cable attached
my application will not start at ‘Power on’ OR when resetting the board using the ‘Reset button’.
Note: If I remove the USB cable and power the board using my auxillary power supply the application will
start on ‘Power on’ and upon pressing the ‘Reset button’
If I do a ‘Ping’ using MFDeploy, the application starts.
I was ‘Thinking’ (Which often gets me in trouble) that it may be related to the USB Driver I am using.
Because of some minor issues I was having with my Spider I recently changed my USB driver to
WinUSB. I found this information at:
Could this driver be causing my problem?
I really do not want to arbitrarily change the USB driver.
Could one of the GHI experts recommend which USB driver I should use that will work well with my ChipworkX AND my Spider?
Sorry about all my questions on my ChipworkX Development System.
Have a GREAT day!
