ChipworkX Development System Factory Calibration
I just powered up my board for the first time and found (using the pre loaded sample application) the touchscreen and accelerometer to be severly out of calibration.
Does it normally ship to the customer this way?
Jason
The touch screen is resistive and so you need a stylus or something pointy to use it. The film on the screen may effect it as well.
I am not sure what you mean by the accelerometer calibration as it only ships with a simple demo
I start up the device on a level surface yet the pong platform is biased heavily in one axis. Is the film you stated the packaging film or the thicker film underneath?
Looks like it was bad power from the USB port causing the problem. Thanks for the quick reply Gus!
Jason
