Is there an update on the VGA adapter
Hi GUS,
How about an update on the VGA Adapter
In production so few days
just seen the vga module. is there a way to hook it on the chipworkx board?
Yes but there are about 20 wires you need to add. You can use 3 extender modules ot get out teh different signals and then wire these to the devsys board.
@ gus : I assume that these wires be connected to the connection of the SV5 devsystem. if so the SV5 on the development board has 24 outpins.
Yes. You must read the devsys schematics and understand it well and must understand the LCD signals to the ones on gadgeteer sockets.
Is it possible? Yes but we can provide limited help.
@ Gus.
Im trying something similar to Embed84, but im using the EMX devsys. I can get the LCD signals out using the extender modules and some wiring.
It seems to work with the T35 display module, but I cannot get the video_out module to work.
I’ve tried the configurations mentioned in the support section, but they dont seem to be the correct ones.
Could it be that I’m missing something here or is there something wrong?
You need to use the driver provided, the gadgeteer drivers. FEZ Spider will be an easy way to evaluate this.
@ Gus:
Ok thx, I got it to work, didn’t realize the touch interface should also be connected.
That is not touch, that is actually configuration.
Ahhhh ok, now I get it.
Was looking at the wrong socket, lol
