[url=https://channel9.msdn.com/coding4fun/blog/FEZ-HAT-UWP-and-Azure-IoT]Shows | Microsoft Learn
[quote]1. Raspberry Pi 2 device with Windows 10 Iot Core
2. FEZ HAT sensor hat.
3. Azure IoT Hub
The walkthrough will guide you through using a Windows 10 Universal Application, the sensors get the raw data and format it into a JSON string. That string is then shuttled off to the Azure IoT Hub, where it gathers the data and you can communicate commands directly back to the device. This walkthrough will take approx. 90 mins to complete.
[/quote]
