Changing time has a strange effect on the read timeout and causes a read to block for infinite.
Following example changes the time while reading from a USB serial device.
Device used is a FEZ Domino.
I expected the read timeout would have a timeout that is independant from the Domino’s time.
using GHIElectronics.NETMF.USBHost;
namespace Test
public static USBH_SerialUSB _serialUsb;
USBHostController.DeviceConnectedEvent += DeviceConnectedEvent;
Thread.Sleep(5000);
Debug.Print("Changing time");
Microsoft.SPOT.Time.TimeService.SetUtcTime(new DateTime(2012,3,30,17,58,00).Ticks);
Debug.Print("Changed time");
public static void SerialWorker()
byte[] buffer = new byte[128];
int bytesRead;
Debug.Print("Reading");
long d0 = DateTime.Now.Ticks;
bytesRead = _serialUsb.Read(buffer, 0, buffer.Length);
long d1 = DateTime.Now.Ticks;
Debug.Print("Read " + bytesRead.ToString() + " bytes, blocked for " + ((d1-d0)/TimeSpan.TicksPerMillisecond).ToString() + " ms");
public static void DeviceConnectedEvent(USBH_Device device)
Debug.Print("USB connected");
if (device.TYPE == USBH_DeviceType.Serial_FTDI)
switch (device.TYPE)
case USBH_DeviceType.Serial_FTDI:
_serialUsb = new USBH_SerialUSB(device, 9600, System.IO.Ports.Parity.None, 8, System.IO.Ports.StopBits.One);
break;
//_serialUsb.ReadTimeout = 500;
_serialUsb.Open();
Thread serialUsbThread = new Thread(SerialWorker);
serialUsbThread.Start();
Output is
USB connected
Reading
Read 0 bytes, blocked for 501 ms
Reading
Read 0 bytes, blocked for 500 ms
Reading
Reading
Reading
Reading
Changing time
Changed time
Changing time
Changed time
Changing time
Changed time
