Cerbuino UART3 mapped to which com port?
I have scoured the docs and can’t find any reference to which COM port UART3 (Arduino connection for TX and RX) maps to in the SerialPort class?
I see UART6 is COM1 for the XBee in a search on the forum but nothing about UART3.
@ Dave McLaughlin - It’s the same as Socket 1 so…
 string comName = GT.Socket.GetSocket(1, false, null, "").SerialPortName;
so “COM3”;
Ah ha. So it is.
Useful code though. Never knew about that one so thanks.
@ Dave McLaughlin - sweet - what’s the project?
Building a small battery powered unit to allow me to get GSM coverage data for remote data monitoring of CBM wells prior to the main systems being installed.
UART3 is connected to a GSM/GPRS shield.
N18 for display and a compass module to record the direction. Unit will be mounted to a yagi high gain antenna and the operator slowly rotates 360 and I will capture the GSM signal as he does. Later I extract the data from the SD card and process this. It also records the GPS location.
:slight_smile:
@ Dave McLaughlin - Sounds v cool - look forward to the finished article and showcase :wink:
Oh rats.
Can’t use the UART3 as the N18 display uses these pins as GPIO
:frowning:
May have to change to the HD44780 display instead. That can connect to the unused socket 3.
