Using the Cerbuino in combination with the seed cellular radio.
I downloaded the driver from Seed.
Now the problem is that the size off the cellular radio assembly is 500KB! , and seems to be too large to fit into a Cerbuino…
Could that be the case? If so, what is the alternative besides buying another CPU board?
Seeed drivers are part of your SDK. Please use from our SDK first.
Gus, Which SDK are you refering to ? I searched all the SDK I downloaded form GHI , Microsoft…
The GHI “package” it has everything.
Finaly found the cause: gadgeteer.dll 4.1 included the serial methods, gadgeteer.dll 4.2 did not. After including Gadgeteer.Serial all references were there.
Case closed.
