Thanks for the “101010” tip, but it hasn’t worked (as can be seen from previous replies) - it just acts like “submit”, sorry! Hope this is more readable.
Reproduced code :-
// Code for flashing LED
//… #include …
#include <stm32f4xx.h>
#include <stdio.h>
//…#defines from stm32f4xx_discovery
typedef enum
GPIO_Speed_2MHz = 0x00,
GPIO_Speed_25MHz = 0x01,
GPIO_Speed_50MHz = 0x02,
GPIO_Speed_100MHz = 0x03
}GPIOSpeed_TypeDef;
#define IS_GPIO_SPEED(SPEED) (((SPEED) == GPIO_Speed_2MHz) || ((SPEED) == GPIO_Speed_25MHz) ||
((SPEED) == GPIO_Speed_50MHz)|| ((SPEED) == GPIO_Speed_100MHz))
typedef enum
GPIO_Mode_IN = 0x00,
GPIO_Mode_OUT = 0x01,
GPIO_Mode_AF = 0x02,
GPIO_Mode_AN = 0x03
}GPIOMode_TypeDef;
#define IS_GPIO_MODE(MODE) (((MODE) == GPIO_Mode_IN) || ((MODE) == GPIO_Mode_OUT) ||
((MODE) == GPIO_Mode_AF)|| ((MODE) == GPIO_Mode_AN))
typedef enum
GPIO_OType_PP = 0x00,
GPIO_OType_OD = 0x01
}GPIOOType_TypeDef;
#define IS_GPIO_OTYPE(OTYPE) (((OTYPE) == GPIO_OType_PP) || ((OTYPE) == GPIO_OType_OD))
typedef enum
GPIO_PuPd_NOPULL = 0x00,
GPIO_PuPd_UP = 0x01,
GPIO_PuPd_DOWN = 0x02
}GPIOPuPd_TypeDef;
#define IS_GPIO_PUPD(PUPD) (((PUPD) == GPIO_PuPd_NOPULL) || ((PUPD) == GPIO_PuPd_UP) ||
((PUPD) == GPIO_PuPd_DOWN))
#define GPIO_Pin_0 ((uint16_t)0x0001) /* Pin 0 selected /
#define GPIO_Pin_1 ((uint16_t)0x0002) / Pin 1 selected /
#define GPIO_Pin_2 ((uint16_t)0x0004) / Pin 2 selected /
#define GPIO_Pin_3 ((uint16_t)0x0008) / Pin 3 selected /
#define GPIO_Pin_4 ((uint16_t)0x0010) / Pin 4 selected /
#define GPIO_Pin_5 ((uint16_t)0x0020) / Pin 5 selected /
#define GPIO_Pin_6 ((uint16_t)0x0040) / Pin 6 selected /
#define GPIO_Pin_7 ((uint16_t)0x0080) / Pin 7 selected /
#define GPIO_Pin_8 ((uint16_t)0x0100) / Pin 8 selected /
#define GPIO_Pin_9 ((uint16_t)0x0200) / Pin 9 selected /
#define GPIO_Pin_10 ((uint16_t)0x0400) / Pin 10 selected /
#define GPIO_Pin_11 ((uint16_t)0x0800) / Pin 11 selected /
#define GPIO_Pin_12 ((uint16_t)0x1000) / Pin 12 selected /
#define GPIO_Pin_13 ((uint16_t)0x2000) / Pin 13 selected /
#define GPIO_Pin_14 ((uint16_t)0x4000) / Pin 14 selected /
#define GPIO_Pin_15 ((uint16_t)0x8000) / Pin 15 selected /
#define GPIO_Pin_All ((uint16_t)0xFFFF) / All pins selected */
#define IS_GPIO_PIN(PIN) ((((PIN) & (uint16_t)0x00) == 0x00) && ((PIN) != (uint16_t)0x00))
#define IS_GET_GPIO_PIN(PIN) (((PIN) == GPIO_Pin_0) ||
((PIN) == GPIO_Pin_1) ||
((PIN) == GPIO_Pin_2) ||
((PIN) == GPIO_Pin_3) ||
((PIN) == GPIO_Pin_4) ||
((PIN) == GPIO_Pin_5) ||
((PIN) == GPIO_Pin_6) ||
((PIN) == GPIO_Pin_7) ||
((PIN) == GPIO_Pin_8) ||
((PIN) == GPIO_Pin_9) ||
((PIN) == GPIO_Pin_10) ||
((PIN) == GPIO_Pin_11) ||
((PIN) == GPIO_Pin_12) ||
((PIN) == GPIO_Pin_13) ||
((PIN) == GPIO_Pin_14) ||
((PIN) == GPIO_Pin_15))
#define GPIO_PinSource0 ((uint8_t)0x00)
#define GPIO_PinSource1 ((uint8_t)0x01)
#define GPIO_PinSource2 ((uint8_t)0x02)
#define GPIO_PinSource3 ((uint8_t)0x03)
#define GPIO_PinSource4 ((uint8_t)0x04)
#define GPIO_PinSource5 ((uint8_t)0x05)
#define GPIO_PinSource6 ((uint8_t)0x06)
#define GPIO_PinSource7 ((uint8_t)0x07)
#define GPIO_PinSource8 ((uint8_t)0x08)
#define GPIO_PinSource9 ((uint8_t)0x09)
#define GPIO_PinSource10 ((uint8_t)0x0A)
#define GPIO_PinSource11 ((uint8_t)0x0B)
#define GPIO_PinSource12 ((uint8_t)0x0C)
#define GPIO_PinSource13 ((uint8_t)0x0D)
#define GPIO_PinSource14 ((uint8_t)0x0E)
#define GPIO_PinSource15 ((uint8_t)0x0F)
#define IS_GPIO_PIN_SOURCE(PINSOURCE) (((PINSOURCE) == GPIO_PinSource0) ||
((PINSOURCE) == GPIO_PinSource1) ||
((PINSOURCE) == GPIO_PinSource2) ||
((PINSOURCE) == GPIO_PinSource3) ||
((PINSOURCE) == GPIO_PinSource4) ||
((PINSOURCE) == GPIO_PinSource5) ||
((PINSOURCE) == GPIO_PinSource6) ||
((PINSOURCE) == GPIO_PinSource7) ||
((PINSOURCE) == GPIO_PinSource8) ||
((PINSOURCE) == GPIO_PinSource9) ||
((PINSOURCE) == GPIO_PinSource10) ||
((PINSOURCE) == GPIO_PinSource11) ||
((PINSOURCE) == GPIO_PinSource12) ||
((PINSOURCE) == GPIO_PinSource13) ||
((PINSOURCE) == GPIO_PinSource14) ||
((PINSOURCE) == GPIO_PinSource15))
#define RCC_AHB1Periph_GPIOB ((uint32_t)0x00000002)
#define RCC_APB2ENR_IOPAEN ((unsigned long)0x00000004)
#define RCC_APB2ENR_IOPCEN ((unsigned long)0x00000010)
#define TIM_CR1_CEN ((uint16_t)0x0001) /*!<Counter enable */
int RLP_freeclock(void* par0, int * par1, unsigned char * par2)
// the passed arguments /////
// keep these for passing params in and out later
unsigned char * ByteArray = par0;
unsigned int length = par1[0];
unsigned char value = par2[0];
int index;
int loops;
// Blinking LED, using GPIO
RCC->AHB1ENR |= RCC_AHB1Periph_GPIOB;
GPIOB->MODER |= GPIO_Mode_OUT;
GPIOB->OSPEEDR |= GPIO_Speed_100MHz;
GPIOB->PUPDR |= GPIO_PuPd_NOPULL;
GPIOB->OTYPER |= GPIO_OType_PP;
// ignore this till next //*
// while (loops<120)
// GPIOB->BSRRL = GPIO_Pin_0;
// for (index = 0; index < 1000000; index++);
// GPIOB->BSRRH = GPIO_Pin_0;
// for (index = 0; index < 21000000; index++); // delay loop.
// GPIOB->ODR ^= 0x1; // Output Data Register @ bit 13, toggled.
// loops++;
// End of Blinking LED (this all works)
// Free running clock at 2 microsecs, with pulse one microsec wide
RCC->AHB1ENR |= RCC_AHB1ENR_GPIOBEN; // enable the hardware clock to GPIOB
RCC->APB1ENR |= RCC_APB1ENR_TIM2EN; // enable TIM2 clock on peripheral clock
GPIOB->MODER = (1 << 26); // set pin 13 to be general purpose output
// return 1;
NVIC->ISER[0] |= 1<< (TIM2_IRQn); // enable the TIM2 IRQ
// return 2;
// TIM2->PSC = (0x0); // no prescaler, timer counts up in sync with the peripheral clock
TIM2->PSC = 41999; // 2000 ticks per sec prescaler
TIM2->DIER |= TIM_DIER_UIE; // enable update interrupt
// return 3;
// TIM2->ARR = 99; // count to 0 (autoreload value 99) This counts 100 clicks
TIM2->ARR = 1999; // use a longer count, 2000 (with prescaler set to 42000, gives 1 sec tick
// return 4;
TIM2->CR1 |= TIM_CR1_ARPE; // autoreload on
// return 5;
TIM2->CR1 |= TIM_CR1_CEN; // counter enabled
return 6;
TIM2->EGR |= (0x1); // trigger update event to reload timer registers
return 7;
loops = 0;
while (loops<1000)
// do nothing
loops++;
return loops;
int main() // this not used in managed system, only calls to functions above
while(1);
