Powered by USB. I haven’t tried with a PSU yet because it works fine in Gadgeteer and with ANALOG_2 enums. I can’t see it being that.
GHI character display is in socket 3, joystick in socket 2. I also have an arduino CANbus shield in the six pin SMT and the eight pin directly opposite.
If it’s a totally noob coding error on my part, please be kind!
using GHI.Hardware.FEZCerb;
using HD44780_Driver;
// Set up analogue channels for the joystick
static AnalogInput Joystick_x = new AnalogInput((Cpu.AnalogChannel)Pin.PA2);
static double Joy_x = 0;
static AnalogInput Joystick_y = new AnalogInput((Cpu.AnalogChannel)Pin.PA3);
static double Joy_y = 0;
static Display_HD44780 disp = new Display_HD44780(3);
disp.Clear();
Joy_x = Joystick_x.Read();
disp.CursorHome();
disp.PrintString("x = " + Joy_x.ToString("F2"));
Joy_y = Joystick_y.Read();
disp.SetCursor(1, 0);
disp.PrintString("y = " + Joy_y.ToString("F2"));
Thread.Sleep(500);
using CerbBeePins_Config;
namespace HD44780_Driver
/// <summary>
/// A Display_HD44780 module for Microsoft .NET Gadgeteer
/// </summary>
public class Display_HD44780
private OutputPort LCD_RS;
private OutputPort LCD_E;
private OutputPort LCD_D4;
private OutputPort LCD_D5;
private OutputPort LCD_D6;
private OutputPort LCD_D7;
private OutputPort BackLight;
const byte DISP_ON = 0xC; //Turn visible LCD on
const byte CLR_DISP = 1; //Clear display
const byte CUR_HOME = 2; //Move cursor home and clear screen memory
const byte SET_CURSOR = 0x80; //SET_CURSOR + X : Sets cursor position to X
// Note: A constructor summary is auto-generated by the doc builder.
/// <summary></summary>
/// <param name="socketNumber">The socket that this module is plugged in to.</param>
public Display_HD44780(int socketNumber)
switch (socketNumber)
case 1:
LCD_RS = new OutputPort(FEZCerbuino.Pin.Gadgeteer.Socket1.Pin4, false);
LCD_E = new OutputPort(FEZCerbuino.Pin.Gadgeteer.Socket1.Pin3, false);
LCD_D4 = new OutputPort(FEZCerbuino.Pin.Gadgeteer.Socket1.Pin5, false);
LCD_D5 = new OutputPort(FEZCerbuino.Pin.Gadgeteer.Socket1.Pin7, false);
LCD_D6 = new OutputPort(FEZCerbuino.Pin.Gadgeteer.Socket1.Pin9, false);
LCD_D7 = new OutputPort(FEZCerbuino.Pin.Gadgeteer.Socket1.Pin6, false);
BackLight = new OutputPort(FEZCerbuino.Pin.Gadgeteer.Socket1.Pin8, true);
break;
case 2:
LCD_RS = new OutputPort(FEZCerbuino.Pin.Gadgeteer.Socket2.Pin4, false);
LCD_E = new OutputPort(FEZCerbuino.Pin.Gadgeteer.Socket2.Pin3, false);
LCD_D4 = new OutputPort(FEZCerbuino.Pin.Gadgeteer.Socket2.Pin5, false);
LCD_D5 = new OutputPort(FEZCerbuino.Pin.Gadgeteer.Socket2.Pin7, false);
LCD_D6 = new OutputPort(FEZCerbuino.Pin.Gadgeteer.Socket2.Pin9, false);
LCD_D7 = new OutputPort(FEZCerbuino.Pin.Gadgeteer.Socket2.Pin6, false);
BackLight = new OutputPort(FEZCerbuino.Pin.Gadgeteer.Socket2.Pin8, true);
break;
case 3:
LCD_RS = new OutputPort(FEZCerbuino.Pin.Gadgeteer.Socket3.Pin4, false);
LCD_E = new OutputPort(FEZCerbuino.Pin.Gadgeteer.Socket3.Pin3, false);
LCD_D4 = new OutputPort(FEZCerbuino.Pin.Gadgeteer.Socket3.Pin5, false);
LCD_D5 = new OutputPort(FEZCerbuino.Pin.Gadgeteer.Socket3.Pin7, false);
LCD_D6 = new OutputPort(FEZCerbuino.Pin.Gadgeteer.Socket3.Pin9, false);
LCD_D7 = new OutputPort(FEZCerbuino.Pin.Gadgeteer.Socket3.Pin6, false);
BackLight = new OutputPort(FEZCerbuino.Pin.Gadgeteer.Socket3.Pin8, true);
break;
default:
throw new Exception("No socketNumber value found");
Initialize();
/// <summary>
/// This function will enable the display, clean it, and enter 4-bit mode.
/// </summary>
private void Initialize()
LCD_RS.Write(false);
// 4 bit data communication
Thread.Sleep(50);
LCD_D7.Write(false);
LCD_D6.Write(false);
LCD_D5.Write(true);
LCD_D4.Write(true);
LCD_E.Write(true);
LCD_E.Write(false);
Thread.Sleep(50);
LCD_D5.Write(true);
LCD_D4.Write(true);
LCD_E.Write(true);
LCD_E.Write(false);
Thread.Sleep(50);
LCD_D5.Write(true);
LCD_D4.Write(true);
LCD_E.Write(true);
LCD_E.Write(false);
Thread.Sleep(50);
LCD_D5.Write(true);
LCD_D4.Write(false);
LCD_E.Write(true);
LCD_E.Write(false);
SendCmd(DISP_ON);
SendCmd(CLR_DISP);
///<summary>
/// Sends an LCD command.
/// </summary>
private void SendCmd(byte c)
LCD_RS.Write(false); //set LCD to data mode
LCD_D7.Write((c & 0x80) != 0);
LCD_D6.Write((c & 0x40) != 0);
LCD_D5.Write((c & 0x20) != 0);
LCD_D4.Write((c & 0x10) != 0);
LCD_E.Write(true); LCD_E.Write(false); //Toggle the Enable Pin
LCD_D7.Write((c & 0x08) != 0);
LCD_D6.Write((c & 0x04) != 0);
LCD_D5.Write((c & 0x02) != 0);
LCD_D4.Write((c & 0x01) != 0);
Thread.Sleep(1);
LCD_RS.Write(true); //set LCD to data mode
/// <summary>
/// Prints the passed in string to the screen at the current cursor position. Note: This function will move the cursor position after.
/// </summary>
/// <param name="str">The string to print.</param>
public void PrintString(string str)
for (int i = 0; i < str.Length; i++)
Putc((byte)str[i]);
/// <summary>
/// Sends an ASCII character to the LCD at the current cursor position. Note: This function will move the cursor position after.
/// </summary>
/// <param name="c">The character to display.</param>
public void Putc(byte c)
//Thread.Sleep(1);
/// <summary>
/// Clears the screen.
/// </summary>
public void Clear()
SendCmd(CLR_DISP);
/// <summary>
/// Places the cursor at the top left of the screen.
/// </summary>
public void CursorHome()
SendCmd(CUR_HOME);
/// <summary>
/// Set the cursor to the passed in position.
/// </summary>
/// <param name="row">Row of the desired cursor position.</param>
/// <param name="col">Column of the desired cursor position.</param>
public virtual void SetCursor(byte row, byte col)
byte[] row_offsets = new byte[4] { 0x00, 0x40, 0x14, 0x54 };
SendCmd((byte)(SET_CURSOR | row_offsets[row] | col));
/// <summary>
/// Turns the backlight on.
/// </summary>
public void TurnBacklightOn()
BackLight.Write(true);
/// <summary>
/// Turns the backlight off.
/// </summary>
public void ShutBacklightOff()
BackLight.Write(false);
namespace CerbBeePins_Config
/// <summary>
/// Exposes FEZ Cerbuino specific functionality.
/// </summary>
public static class FEZCerbuino
/// <summary>
/// Provides Pin definitions for FEZ Cerbuino.
/// </summary>
public class Pin
/// <summary>
/// Provides Pin definitions for FEZ Cerbuino's Arduino-styled I/O headers.
/// </summary>
public class Digital
/// <summary>Digital I/O.</summary>
public const Cpu.Pin A0 = GHI.Hardware.FEZCerb.Pin.PB1;
public const Cpu.Pin A1 = GHI.Hardware.FEZCerb.Pin.PA5;
public const Cpu.Pin A2 = GHI.Hardware.FEZCerb.Pin.PB0;
public const Cpu.Pin A3 = GHI.Hardware.FEZCerb.Pin.PC3;
public const Cpu.Pin A4 = GHI.Hardware.FEZCerb.Pin.PC1;
public const Cpu.Pin A5 = GHI.Hardware.FEZCerb.Pin.PA4;
public const Cpu.Pin D0 = GHI.Hardware.FEZCerb.Pin.PB11;
public const Cpu.Pin D1 = GHI.Hardware.FEZCerb.Pin.PB10;
public const Cpu.Pin D2 = GHI.Hardware.FEZCerb.Pin.PB12;
public const Cpu.Pin D3 = GHI.Hardware.FEZCerb.Pin.PC14;
public const Cpu.Pin D4 = GHI.Hardware.FEZCerb.Pin.PC15;
public const Cpu.Pin D5 = GHI.Hardware.FEZCerb.Pin.PA8;
public const Cpu.Pin D6 = GHI.Hardware.FEZCerb.Pin.PA10;
public const Cpu.Pin D7 = GHI.Hardware.FEZCerb.Pin.PC4;
public const Cpu.Pin D8 = GHI.Hardware.FEZCerb.Pin.PB13;
public const Cpu.Pin D9 = GHI.Hardware.FEZCerb.Pin.PA9;
public const Cpu.Pin D10 = GHI.Hardware.FEZCerb.Pin.PA15;
public const Cpu.Pin D11 = GHI.Hardware.FEZCerb.Pin.PB5;
public const Cpu.Pin D12 = GHI.Hardware.FEZCerb.Pin.PB4;
public const Cpu.Pin D13 = GHI.Hardware.FEZCerb.Pin.PB3;
public const Cpu.Pin LED1 = GHI.Hardware.FEZCerb.Pin.PB2;
/// <summary>
/// Provides Pin definitions for FEZ Cerbuino's Gadgeteer sockets.
/// </summary>
public class Gadgeteer
/// <summary>
/// Provides Pin definitions for FEZ Cerbuino's Socket 1.
/// </summary>
public class Socket1
public const Cpu.Pin Pin3 = GHI.Hardware.FEZCerb.Pin.PA14;
public const Cpu.Pin Pin4 = GHI.Hardware.FEZCerb.Pin.PB10;
public const Cpu.Pin Pin5 = GHI.Hardware.FEZCerb.Pin.PB11;
public const Cpu.Pin Pin6 = GHI.Hardware.FEZCerb.Pin.PA13;
public const Cpu.Pin Pin7 = GHI.Hardware.FEZCerb.Pin.PB5;
public const Cpu.Pin Pin8 = GHI.Hardware.FEZCerb.Pin.PB4;
public const Cpu.Pin Pin9 = GHI.Hardware.FEZCerb.Pin.PB3;
/// <summary>
/// Provides Pin definitions for FEZ Cerbuino's Socket 2.
/// </summary>
public class Socket2
public const Cpu.Pin Pin3 = GHI.Hardware.FEZCerb.Pin.PA6;
public const Cpu.Pin Pin4 = GHI.Hardware.FEZCerb.Pin.PA2;
public const Cpu.Pin Pin5 = GHI.Hardware.FEZCerb.Pin.PA3;
public const Cpu.Pin Pin6 = GHI.Hardware.FEZCerb.Pin.PA1;
public const Cpu.Pin Pin7 = GHI.Hardware.FEZCerb.Pin.PA0;
public const Cpu.Pin Pin8 = GHI.Hardware.FEZCerb.Pin.PB7;
public const Cpu.Pin Pin9 = GHI.Hardware.FEZCerb.Pin.PB6;
/// <summary>
/// Provides Pin definitions for FEZ Cerbuino's Socket 3.
/// </summary>
public class Socket3
public const Cpu.Pin Pin3 = GHI.Hardware.FEZCerb.Pin.PC0;
public const Cpu.Pin Pin4 = GHI.Hardware.FEZCerb.Pin.PC1;
public const Cpu.Pin Pin5 = GHI.Hardware.FEZCerb.Pin.PA4;
public const Cpu.Pin Pin6 = GHI.Hardware.FEZCerb.Pin.PC5;
public const Cpu.Pin Pin7 = GHI.Hardware.FEZCerb.Pin.PB8;
public const Cpu.Pin Pin8 = GHI.Hardware.FEZCerb.Pin.PA7;
public const Cpu.Pin Pin9 = GHI.Hardware.FEZCerb.Pin.PB9;
/// <summary>
/// Provides Channel definitions for FEZ Cerbuino's PWM capable pins.
/// </summary>
public class PWM
/// <summary>PWM Output</summary>
public const Cpu.PWMChannel D5 = (Cpu.PWMChannel)3;
public const Cpu.PWMChannel A2 = (Cpu.PWMChannel)4;
public const Cpu.PWMChannel A0 = (Cpu.PWMChannel)5;
public const Cpu.PWMChannel D11 = (Cpu.PWMChannel)6;
public const Cpu.PWMChannel D12 = (Cpu.PWMChannel)7;
public const Cpu.PWMChannel D13 = (Cpu.PWMChannel)8;
public const Cpu.PWMChannel D0 = (Cpu.PWMChannel)9;
public const Cpu.PWMChannel D1 = (Cpu.PWMChannel)10;
public const Cpu.PWMChannel D6 = (Cpu.PWMChannel)11;
public const Cpu.PWMChannel D9 = (Cpu.PWMChannel)12;
public const Cpu.PWMChannel D10 = (Cpu.PWMChannel)13;
/// <summary>
/// Provides Channel definitions for FEZ Cerbuino's AnalogIn capable pins.
/// </summary>
public class AnalogIn
/// <summary>Analog Input</summary>
public const Cpu.AnalogChannel A0 = (Cpu.AnalogChannel)10;
public const Cpu.AnalogChannel A1 = (Cpu.AnalogChannel)8;
public const Cpu.AnalogChannel A2 = (Cpu.AnalogChannel)9;
public const Cpu.AnalogChannel A3 = (Cpu.AnalogChannel)7;
public const Cpu.AnalogChannel A4 = (Cpu.AnalogChannel)4;
public const Cpu.AnalogChannel A5 = (Cpu.AnalogChannel)5;
