Yes, I’ve now tested with the same cable on both the uSD and SD card modules, still using the same uSD card but in a SanDisk SD-size adapter in the SD module, and the behaviour is still the same - the SD card module works fine but the uSD module does not.
Now I know there’s some SD card changes coming down from Dat in the next firmware cycle but I’ll still add a little more data here in case it helps.
When I start the app, and then insert the SD card into the uSD module, the whole system appears to lock up. I can’t pause the running app, the debugger seems to have lost connection with the processor (so I assume it’s now deep in core code and not giving the debugger any time).
If I go into MFDeploy, reboot the device, and select USB transport and hit F5 to connect, I can see the timer ticking over. I insert the uSD card and system freezes as it does when debugging in VS.
If however I then disconnect, and reset the device without removing the uSD card, the app starts. I can then attach MFDeploy successfully and things work. If I then reboot the CLR from MFDeploy, I see the boot messages and I also see this:
Assembly: System.Net.Security (4.2.0.0) Attaching deployed file.
Assembly: System.Http (4.2.0.0) Resolving.
Ready.
Using mainboard GHI Electronics FEZCerberus version 1.1
ProgramStarted
SD card has been successfully mounted. You can now read/write/create/delete files
Unmount before removing
I: 0
I: 1
I: 2
I: 3
I: 4
I: 5
The SD card has been unmounted
DO NOT try to access it without mounting it again first
I: 6
I: 7
I: 8
User Cancel...
So it works fine if the card is already mounted when the app starts. I wonder if that behaviour difference makes sense to you Dat?
For completeness, here’s the test code I am using.
using System.Collections;
using Microsoft.SPOT.Touch;
using Gadgeteer.Networking;
using GT = Gadgeteer;
namespace CerbSDTest4Forum
public partial class Program
long i = 0;
// private const Cpu.PWMChannel PWM_LED = Cpu.PWMChannel.PWM_4;
GT.Timer timer = new GT.Timer(1000);
timer.Tick +=<tab><tab>
timer.Start();
Debug.Print("ProgramStarted");
sdCard.SDCardMounted += new SDCard.SDCardMountedEventHandler(sdCard_SDCardMounted);
sdCard.SDCardUnmounted += new SDCard.SDCardUnmountedEventHandler(sdCard_SDCardUnmounted);
timer.Start();
Debug.Print("I: " + i++);
void sdCard_SDCardUnmounted(SDCard sender)
Debug.Print("The SD card has been unmounted");
Debug.Print("DO NOT try to access it without mounting it again first");
void sdCard_SDCardMounted(SDCard sender, GT.StorageDevice SDCard)
Debug.Print("SD card has been successfully mounted. You can now read/write/create/delete files");
Debug.Print("Unmount before removing");
