Cerberus stand-alone
Hello everyone,
I am new to the forum and to the world of .NET Gadgeteer. So I must apologise if my questions start of very basic. But I do hope to grow in competence with increased use of the Fez Cerberus and lots of practice.
My question is re the stand-alone capability of the hardware. Is it possible for the mainboard and peripherals to function autonomously once the necessary system code has been developed and downloaded? I ask this because, for starters, I have noted that the mainboard/system is powered through the USB port.
For similar systems, such as the PIC microcontroller, the programmer is simply disconnected and the ‘system’ functions freely of the PC.
Any assistance that any one within the forum can provide would be most appreciated
Best Regards
Givi
Welcome to the forum. All of the GHI boards can be powered on their own. The DP power module also has a barrel jack. A USB cable does not need to be hooked to a computer to provide power either. You can plug it directly into a transformer made to accept a female A jack. Many cell phones charge this way. You can also power all of the boards by providing your own regulated power directly to the appropriate pins. This latter technique should only be done by advanced users however, as it bypasses the power protection circuitry found on the DP module.
I believe all boards are able to work stand alone. I don’t have Cerberus but I am having Cerb40 and able to work with external power source ( without pc host USB).
I’ve been running the Cerb40 off a LiPo pack for awhile now, works just fine; as they all will.
Cerb40 works fine standalone. GHI specify a 3.3 V power supply, but the Cerb40 can be powered from 1.8V to 3.6V with success, I tested it.
I have not soldered the 3.3V regulator on the card Cerb40.
It is easier to use a Cerb40 than an assembly with a PIC.
You use the USB port to download and debug the program but once you have disconnected the USB cable, downloaded program works standalone.
Best Regards
Christian
Hello to ALL,
Thank you each and everyone for taking a look at my question and for providing very useful information.
Based on what ransomhall has told me, the best approach to start development work is to utilise the DP Module in conjunction with an appropriate power supply (app12V, 1A, 2.1mm jack).
Ramsomhall, Ive looked at the DP Module schematics, is it accurate to say that the adapter to be used is a positive centred unit?
Based on what ChristianJack, Nila and Skewworks have indicated. I can graduate to the Cerb40 once I have done my development work and I can power this board directly with the appropriate voltage levels.
Once again, thanks everyone
Givi
Yes, all GHI boards that have a barrel jack are center positive.
Hey ramsomhall,
thanks for the confirmation. The FEZ Cerberus arrived today and I managed to track down a 12V, 1A adapter with a 2.1mm jack.
Just fired up the hardware and power LEDs are all glowing fine!!! I’m a hardware guy, love how small and neat everything is.
Currently running the test code in the FEZ Cerberus Basic Kit Guide, hope to see a blinking LED soon.
Yeah… I’m a sad case, but I’m going to keep at it until I’ve mastered coding and can really make this board blaze!
Thanks again ramsomhall
Jeevan
