Cerberus - Solved!
I’m trying to use ceberus (have experience with spider) what should eb the mainBoard type? the only defined types I’ve found are Hydra / Spider
what should I specify using Cerberus/ G120 or any other main board?
Do you mean in the Visual Studio Designer?? If so it sounds like you havent got the latest SDK installed. It should show up in the designer toolbox.
Make sure to update the firmware on the cerberus too.
