Checking the native code for Cerb-family, in STM32F4_usart_functions.cpp,
The configuration function for USART, StopBits argument is completely ignored and always configures the usart for one stop bit. Unless I’m missing something huge elsewhere in the code, I fail to see how we can configure usart with two stop bits. Is it a bug or a feature ?
BOOL CPU_USART_Initialize( int ComPortNum, int BaudRate, int Parity, int DataBits, int StopBits, int FlowValue )
if (ComPortNum >= TOTAL_USART_PORT) return FALSE;
if (Parity >= USART_PARITY_MARK) return FALSE;
GLOBAL_LOCK(irq);
ptr_USART_TypeDef uart = g_STM32F4_Uart_Ports[ComPortNum];
UINT32 clk;
// enable UART clock
if (ComPortNum == 5) { // COM6 on APB2
RCC->APB2ENR |= RCC_APB2ENR_USART6EN;
clk = SYSTEM_APB2_CLOCK_HZ;
} else if (ComPortNum) { // COM2-5 on APB1
RCC->APB1ENR |= RCC_APB1ENR_USART2EN >> 1 << ComPortNum;
clk = SYSTEM_APB1_CLOCK_HZ;
} else { // COM1 on APB2
// USART1 is not used on Cerberus but USART6 is used on Cerbuino.
// This is just for Cerbuino.
//RCC->APB2ENR |= RCC_APB2ENR_USART1EN;
//clk = SYSTEM_APB2_CLOCK_HZ;
// baudrate
UINT16 div = (UINT16)((clk + (BaudRate >> 1)) / BaudRate); // rounded
uart->BRR = div;
// control
UINT16 ctrl = USART_CR1_TE | USART_CR1_RE;
if (DataBits == 9) ctrl |= USART_CR1_M;
if (Parity) ctrl |= USART_CR1_PCE;
if (Parity == USART_PARITY_ODD) ctrl |= USART_CR1_PS;
uart->CR1 = ctrl;
if (DataBits == USART_STOP_BITS_ONE) DataBits = 0;
uart->CR2 = (UINT16)(DataBits << 12);
ctrl = 0;
if (FlowValue & USART_FLOW_HW_OUT_EN) ctrl |= USART_CR3_CTSE;
if (FlowValue & USART_FLOW_HW_IN_EN) ctrl |= USART_CR3_RTSE;
uart->CR3 = ctrl;
GPIO_PIN rxPin, txPin, ctsPin, rtsPin;
CPU_USART_GetPins(ComPortNum, rxPin, txPin, ctsPin, rtsPin);
UINT32 alternate = 0x72; // AF7 = USART1-3
//if (ComPortNum >= 3) alternate = 0x82; // AF8 = UART4-6
if (ComPortNum == 0) alternate = 0x82; // AF8 = UART4-6 -->> Only because USART1 is really USART6
CPU_GPIO_DisablePin(rxPin, RESISTOR_PULLUP, 0, (GPIO_ALT_MODE)alternate);
CPU_GPIO_DisablePin(txPin, RESISTOR_DISABLED, 1, (GPIO_ALT_MODE)alternate);
if (ctsPin == GPIO_PIN_NONE) return FALSE;
CPU_GPIO_DisablePin(ctsPin, RESISTOR_DISABLED, 0, (GPIO_ALT_MODE)alternate);
if (rtsPin == GPIO_PIN_NONE) return FALSE;
CPU_GPIO_DisablePin(rtsPin, RESISTOR_DISABLED, 1, (GPIO_ALT_MODE)alternate);
CPU_USART_ProtectPins(ComPortNum, FALSE);
switch (ComPortNum) {
//case 0: CPU_INTC_ActivateInterrupt(USART1_IRQn, STM32F4_USART_Interrupt0, 0); break;
case 0: CPU_INTC_ActivateInterrupt(USART6_IRQn, STM32F4_USART_Interrupt0, 0); break;
case 1: CPU_INTC_ActivateInterrupt(USART2_IRQn, STM32F4_USART_Interrupt1, 0); break;
case 2: CPU_INTC_ActivateInterrupt(USART3_IRQn, STM32F4_USART_Interrupt2, 0); break;
case 3: CPU_INTC_ActivateInterrupt(UART4_IRQn, STM32F4_USART_Interrupt3, 0); break;
case 4: CPU_INTC_ActivateInterrupt(UART5_IRQn, STM32F4_USART_Interrupt4, 0); break;
case 5: CPU_INTC_ActivateInterrupt(USART6_IRQn, STM32F4_USART_Interrupt5, 0);
uart->CR1 |= USART_CR1_UE; // start uart
return TRUE;
