Hi there fellow Gadgeteers, and especially Taylorza.
I’m having a bit of trouble using the Cerberus DL40 Programmer (https://www.ghielectronics.com/community/forum/topic?id=10515) to program my DL40. It goes up to where it says “Connecting…”, but then just seems to hang there.
I tried connecting Socket 7 to both sockets (uplink and downlink) on the DL40, but it did not really make a difference. I also tried using two different Cerberus boards and two different DL40’s and two cables. Same thing every time.
This is what I get:
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\data\dev\gadgeteer\samples\CerberusDL40Programmer\CerberusDL40Programmer\bin\Debug\le\CerberusDL40Programmer.exe', Symbols loaded.
The thread '<No Name>' (0x2) has exited with code 0 (0x0).
Press button to start flash
Beginning chip reflash...
Connecting..
One thing I have to point out though… since I do not have a button module to put on Socket 6, I simply started the Flash thread from the main loop as shown below. But I do not think that should be a problem.
Debug.Print("Press button to start flash");
Thread.Sleep(10000);
flashThread = new Thread(FlashThreadStart);
flashThread.Start();
I am sure this is just something small, but any advice would be welcome.
